August 17, 2021, 23:12 |
Using foam-extend 4.0
Bailey
Rep Power: 5 |
I am trying to download foam-extend and am having trouble installing. Currently to access the openfoam environment, I change to my openFoam folder in terminal (I am using MacOS), and then run openfoam8-macos -p which gets me into the openFOAM environment which is the openfoam v8 docker image. I have been trying to install foam-extend to that environment but have had no luck so far. I want to be able to access the other tutorials in foam-extend such as the immersedBoundary stuff. Any advice? Thanks!!
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 03:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
