[OpenFOAM.com] Solid4Foam - Compilation Error on OpenFOAM-7 |
July 22, 2021, 11:36 |
Philipp Conen
Rep Power: 5 |
Dear Foamers,
taking research on Fluid-Structur-Interaction (FSI) package, I found the package "Solid4Foam". First I compiled OpenFOAM V7 (https://openfoamwiki.net/index.php/I...7/Ubuntu/18.04) Following the steps mentioned in: https://www.researchgate.net/profile...am-toolbox.pdf I got the message of missing "gfortran" package. I installed it via: Code:
sudo apt update sudo apt install gfortran Also I tried to compile it in foam-exent-4.0, but I also get some errors: Code:
philipp-4.0/applications/bin/linux64GccDPOpt/solids4Foam /usr/bin/ld: cannot find -lgfortran collect2: error: ld returned 1 exit status /home/philipp/foam/foam-extend-4.0/wmake/Makefile:159: recipe for target '/home/philipp/foam/philipp-4.0/applications/bin/linux64GccDPOpt/solids4Foam' failed make[1]: *** [/home/philipp/foam/philipp-4.0/applications/bin/linux64GccDPOpt/solids4Foam] Error 1 /home/philipp/foam/foam-extend-4.0/wmake/MakefileApps:39: recipe for target 'solids4Foam' failed make: *** [solids4Foam] Error 2 make: Target 'application' not remade because of errors. Could anybody help me please? I am using Ubuntu 18.4 Last edited by philippconen; July 22, 2021 at 12:59. Reason: Wrong file uploaded |
July 28, 2021, 13:14 |
Philipp Conen
Rep Power: 5 |
September 22, 2021, 10:42 |
#3 | |
Filippo Azzini
Rep Power: 6 |
I have the same problem but i can not fix it following that tread, i'm working on Ubuntu 20.04and foam extended 4.0, someone can help? thanks a lot |
compilation, installation, openfoam7, pow, solid4foam |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 07:54 |
[OpenFOAM.org] OpenFOAM 5.0: sudden new compilation error on on the Titan supercomputer (Cray) | wildfire230 | OpenFOAM Installation | 1 | July 15, 2018 11:06 |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 12:50 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 04:19 |
OpenFoam 2.1.x /2.2.0 compilation failed on Ubuntu 12.04/10 64bit | keepfit | OpenFOAM Installation | 2 | March 26, 2013 10:43 |
