[OpenFOAM.com] copy or recompile OF for modified solvers |
July 2, 2021, 12:29 |
Josh McCraney
Rep Power: 9 |
Hi all
I am running an old version of OpenFOAM that has some new solvers built. Is there a way for me to copy OpenFOAM from that computer and put it on a different one so the new solvers run, or would I have to install that version of OpenFOAM, copy the solvers, and then recompile? Thanks so much |
July 5, 2021, 12:14 |
#2 | |
Mark Olesen
Rep Power: 40 |
Hi Josh, You will need more specifics. Depends on OS versions, MPI, compilers etc. No simple generalization possible. Cheers, /mark |
Types of solvers | CFD-Junior | Main CFD Forum | 6 | April 14, 2019 18:25 |
FloEFD Copy Component Instance | cattewell | FloEFD, FloWorks & FloTHERM | 3 | September 14, 2018 10:38 |
How can I copy a solver/class to my directory? | CellZone | OpenFOAM Programming & Development | 2 | May 13, 2016 14:28 |
Is there a difference between Riemann solvers and characteristic based solvers? | linkamp | Main CFD Forum | 3 | February 18, 2016 10:12 |
[ICEM] Copy Bunching to selected and parallel? | Andrew Norfolk | ANSYS Meshing & Geometry | 1 | February 8, 2016 10:02 |
