[foam-extend.org] Problems installing the FSI-toolkit on foam-extend-4.0 |
June 20, 2021, 18:50 |
Rep Power: 5 |
I tried to install the FSI-toolkit on foam-extend-4.0 on Ubuntu 18.04. LTS. I am working with the Oracle Virtual Box. After successful installing of foam-extend-4.0 (I tried the blockMesh-command and it was working) I installed the FSI-toolkit with the following link: 1) https://www.researchgate.net/publica...rse_Notes_2019 (page 33) I did all steps for installing the toolkit and started to run the tutorial 'beamInCrossFlow'. After a few seconds the simulation stops with the following error message: Code:
./Allrun Running blockMesh on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid Running setSet on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid Running setsToZones on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid Running blockMesh on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid Running setSet on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid Running setsToZones on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file setInletVelocity.C SOURCE=setInletVelocity.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I../../../../src/fluidSolidInteraction/lnInclude -I/home/pit1/foam/foam-extend-4.0/src/finiteVolume/lnInclude -I/home/pit1/foam/foam-extend-4.0/src/finiteArea/lnInclude -I/home/pit1/foam/foam-extend-4.0/src/meshTools/lnInclude -I/home/pit1/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude -I/home/pit1/foam/foam-extend-4.0/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/home/pit1/foam/foam-extend-4.0/src/foam/lnInclude -I/home/pit1/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setInletVelocity.o /usr/bin/ld: cannot find -lfluidSolidInteraction collect2: error: ld returned 1 exit status /home/pit1/foam/foam-extend-4.0/wmake/Makefile:186: recipe for target '/home/pit1/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsetInletVelocity.so' failed make: *** [/home/pit1/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsetInletVelocity.so] Error 1 Running fsiFoam on /home/pit1/foam/pit1-4.0/FluidSolidInteraction/run/fsiFoam/beamInCrossFlow/fluid I don't know how to solve the problem. I still reinstalled the foam-extend version and the toolkit on a new virtual machine and it is still not working... Can you help me? Any help is appreciated! |
[foam-extend.org] Problems on installing Foam-extend 4.0/ swak4Foam on ubuntu18.0.4 | XJ_Wang | OpenFOAM Installation | 22 | December 19, 2021 08:55 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
Using createPatch and cyclicAMI in FOAM Extend 4.0 | mekim | OpenFOAM Pre-Processing | 1 | June 20, 2020 06:19 |
[FSI] Installing FSI toolkit in foam-extend 4.0 | treem22 | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 5 | August 8, 2019 07:06 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 05:08 |
