[OpenFOAM.com] Can I avoid installing Foam-Extend? |
Paritosh Usmanpurkar
Rep Power: 5 ![]() |
Hello Foamers,
I wish to simulate Viscoelastic fluid flow and have currently installed OpenFOAM v2012(ESI version). But it does not have the feature for Viscoelastic flow. Can I just copy-paste the necessary files(libraries for viscoelastic models and solvers) from extend version to the respective folder in my version and compile it? Will that work? Thanks! |
Nat K
Rep Power: 8 ![]() |
There is a toolbox available that can be used with OpenFOAM Foundation V6 and V7. The toolbox is called rheoTool.
https://github.com/fppimenta/rheoTool I find foam-extend a bit buggy, so you find it better to use the standard OF versions and the toolbox. Hope this helps. |
#3 | |
extend 4.0, openfoam, viscoelastic |
SimpleFoam cannot open include file | Marija | OpenFOAM Running, Solving & CFD | 1 | October 28, 2020 10:35 |
[foam-extend.org] error installing foam extend 1.6 in ubuntu 12.04 | christos | OpenFOAM Installation | 1 | May 9, 2016 17:20 |
[OpenFOAM] Take derivative of mean velocity in paraFoam | hiuluom | ParaView | 13 | April 26, 2016 06:44 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Derivative of velocity and mean velocity | hiuluom | OpenFOAM Post-Processing | 1 | May 29, 2015 23:42 |
