[foam-extend.org] Issues Running foam-extend Utilities on WSL
Old   January 18, 2021, 19:33
Default Issues Running foam-extend Utilities on WSL
Sayre Satterwhite
Snayer is on a distinguished road
I am attempting to make the switch to foam-extend 4.1 from Openfoam8. I am using WSL with Ubuntu 18.04. I believed that I had installed everything correctly after much trial (everything in the foam-extend folder seems to be present, including all the utilities), however, when I go to run a utility on a case, such as blockMesh, it says "command not found".
I tried both the tutorials with foam-extend and some of the cases I've been working on in OpenFOAM8, however, I get the same result.
Do I have everything installed correctly, or am I going about foam-extend in the wrong mindset coming from OpenFOAM8?
Thank you
Snayer is offline   Reply With Quote
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
