[OpenFOAM.com] Docker results different from OpenFoam native |
January 1, 2021, 20:59 |
Ivan
Rep Power: 6 |
I'm trying to validate a well-known case, turbulent flow over NACA0012. Information of the validation ca be found here: https://turbmodels.larc.nasa.gov/naca0012_val.html I simulated properly the case with the version of OpenFoam v2006, obtaining succefull results. I can say that I validated the case because I got accuracy values for Cl and Cd for differents angles of attacks (0º, 3º, 6º, 9º, 12º and 15º). I did that with two different turbulence models (RAS-Spalart Allmaras and RAS-KwSST) using the solver simpleFoam. The problem is the following one. I tried to run the SAME case with a version of OpenFoam installed by means of Docker. (IN THE SAME LAPTOP). Both are supposed to be the same version but the results are differents (Relative error 30 %) and it isn't related with the time of convergence. Has anyone suspect where can be the problem? If someone is interested in look over the code, the case for AoA 3 degrees is here: https://drive.google.com/file/d/1p2P...ew?usp=sharing The case is ready to run with simpleFoam. Thank for your time. |
Getting Started with OpenFOAM | wyldckat | OpenFOAM | 26 | June 21, 2024 07:54 |
k and omega at inlet for k-omega SST | driu | OpenFOAM Running, Solving & CFD | 10 | March 5, 2021 11:48 |
OpenFOAM course for beginners | Jibran | OpenFOAM Announcements from Other Sources | 2 | November 4, 2019 09:51 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 04:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 14:36 |
