[OpenFOAM.org] Problem with installation of OpenFoam 4.1 on Ubuntu 20.04 LTS |
December 2, 2020, 04:15 |
Ferenc Safranyik
Rep Power: 5 |
Dear All,
I am very interesting in CFD simulations and I would like to use OpenFoam. I have tried to install OpenFoam 4.1 on Ubuntu 20.04 LTS. These steps were followed and these instructions were considered as well, however I faced a problem but I do not understand what can be the mistake (I am not an experienced Ubuntu user). I got follwong error messages in Terminal after an hour of compiling: What should I do to solve the problem? update: The problem was solved with a fresh reinstall. blockMesh and simpleFoam are working but paraFoam throws the following error: What should I do? Thanks in advance, Feri Last edited by safranyikf; December 3, 2020 at 06:02. |
December 3, 2020, 05:49 |
Ferenc Safranyik
Rep Power: 5 |
following a fresh reinstall the blockMesh and simpleFoam is working, however paraFoam throws the following error: Code:
paraFoam -vtk Created temporary 'pitzDaily.foam' -------------------------------------------------------------------------- It looks like opal_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during opal_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): opal_shmem_base_select failed --> Returned value -1 instead of OPAL_SUCCESS -------------------------------------------------------------------------- -------------------------------------------------------------------------- It looks like orte_init failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during orte_init; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): opal_init failed --> Returned value Error (-1) instead of ORTE_SUCCESS -------------------------------------------------------------------------- -------------------------------------------------------------------------- It looks like MPI_INIT failed for some reason; your parallel process is likely to abort. There are many reasons that a parallel process can fail during MPI_INIT; some of which are due to configuration or environment problems. This failure appears to be an internal failure; here's some additional information (which may only be relevant to an Open MPI developer): ompi_mpi_init: ompi_rte_init failed --> Returned "Error" (-1) instead of "Success" (0) -------------------------------------------------------------------------- *** An error occurred in MPI_Init *** on a NULL communicator *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, *** and potentially your MPI job) [ubuntu:535647] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed! |
openfoam 4.1, ubuntu 20.04 |
[OpenFOAM.org] OpenFOAM 5 installation on Ubuntu 20.04 | azamat | OpenFOAM Installation | 6 | November 28, 2022 07:04 |
[swak4Foam] Swak4foam installation error with OF 2.2.0 (Ubuntu 12.04 LTS) | vbchris | OpenFOAM Community Contributions | 8 | March 25, 2021 20:11 |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Openfoam 2.1 installation in ubuntu 12.04 | jsm | OpenFOAM Installation | 11 | May 7, 2012 04:56 |
