[OpenFOAM.com] Avalanche error: OpenFOAM-v1906 installation on Ubuntu 20.04.1 |
November 8, 2020, 16:11 |
Hüseyin Can Önel
Rep Power: 8 |
I'm getting an error regarding "avalanche" while I build OpenFOAM-v1906 from source on Ubuntu 20.04.1: Code:
ld: /home/hconel/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib/libfaAvalanche.so g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/deposition/depositionModel/depositionModel.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/deposition/depositionModel/depositionModelNew.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/deposition/depositionOff/depositionOff.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/deposition/Stoppingprofile/Stoppingprofile.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/entrainment/entrainmentModel/entrainmentModel.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/entrainment/entrainmentModel/entrainmentModelNew.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/entrainment/entrainmentOff/entrainmentOff.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/entrainment/Erosionenergy/Erosionenergy.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/entrainment/Front/Front.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/entrainment/IsslerFC/IsslerFC.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/entrainment/Medina/Medina.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/friction/frictionModel/frictionModel.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/friction/frictionModel/frictionModelNew.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/friction/PoliquenForterre/PoliquenForterre.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/friction/muI/muI.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/friction/Voellmy/Voellmy.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/friction/kt/kt.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/friction/DarcyWeisbach/DarcyWeisbach.o: No such file or directory g++: error: /home/hconel/OpenFOAM/OpenFOAM-v1906/build/linux64GccDPInt64Opt/modules/avalanche/src/avalanche/friction/ManningStrickler/ManningStrickler.o: No such file or directory make[1]: *** [/home/hconel/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/general:177: /home/hconel/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/lib/libfaAvalanche.so] Error 1 make: *** [/home/hconel/OpenFOAM/OpenFOAM-v1906/wmake/makefiles/apps:29: avalanche] Error 2 The weird thing is I did not get this error on another machine which also runs the same Ubuntu version. Any help will be appreciated. Regards, Huseyin |
November 8, 2020, 17:16 |
Hüseyin Can Önel
Rep Power: 8 |
That was actually my mistake.
I was not able to see the root of the problem since I was checking the log of my second ./Allwmake run, which hides some of the main output. Apparently, I did not have "flex" installed which is actually in the prerequisite list: https://www.openfoam.com/documentati...quirements.php Just install everything here and you are good to go. |
November 12, 2020, 16:30 |
Mark Olesen
Rep Power: 40 |
For 1912 and 2006 versions, you can save the compilation time and use the Ubuntu packs (see the openfoam.com wiki pages)
openfoam 1906, ubuntu 20.04 |
Ansys Installation on Docker Container | mohsen.shiea | ANSYS | 11 | March 14, 2024 11:18 |
how do i fix installation error of ansys 19.0 on ubuntu 18.04 | rid_taki | ANSYS | 15 | June 7, 2021 06:32 |
[CAD formats] MegaCads Installation on Ubuntu | NablaDyn | OpenFOAM Meshing & Mesh Conversion | 13 | May 29, 2020 13:17 |
[OpenFOAM.org] Can't find installation instruction for Openfoam 2.4.x , on Ubuntu 16.04 | titanium | OpenFOAM Installation | 14 | February 20, 2020 11:46 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
