[OpenFOAM.org] OpenFoam singularity container MPI crash
Old   November 5, 2020, 09:22
Default OpenFoam singularity container MPI crash
ves
Veskov Eugene
ves is on a distinguished road
Hi, Foamers!
MPI error with damBreak fine mesh sample on openfoam7 with message "unable to create shared memory BTL coordinate structure",singularity instance stopping only manually, on openfoam2006 mpi failed with "Bus error" if I increase mesh cell number 10 times, basic sample work and 4 times increase work
singularity container build from docker container at home computer with same version docker and singularity as on sumercomputer
OS Centos 7 at home RedHat on supercomputer. sample run on one node with 39 core and 768 GB RAM
How solve this problem?
FOAM_SINGULARITY_IMAGE=work/OPENFOAM_7_SINGULARITY/openfoam7.sif
FOAM_BASHRC=/opt/openfoam7/etc/bashrc
singularity instance start ://openfoam7 --cleanenv
singularity exec $FOAM_SINGULARITY_IMAGE bash -c "source $FOAM_BASHRC && blockMesh -case damBreak"
singularity exec $FOAM_SINGULARITY_IMAGE bash -c "source $FOAM_BASHRC && setFields -case damBreak"
singularity exec $FOAM_SINGULARITY_IMAGE bash -c "source $FOAM_BASHRC && decomposePar -case damBreak"
singularity exec $FOAM_SINGULARITY_IMAGE bash -c "source $FOAM_BASHRC && mpirun -np 4 interFoam -parallel -case damBreak
ves is offline   Reply With Quote
Getting Started with OpenFOAM wyldckat OpenFOAM 26 June 21, 2024 07:54
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 17:38
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Intelbs MPI and performance tools in OpenFOAM hplum OpenFOAM 16 December 16, 2007 15:58
