foam-extend using intel mpi
Old   October 20, 2020, 12:55
Default foam-extend using intel mpi
Ra Miro
ramrebol is on a distinguished road
Hello.
I' trying to install foam-extend 4.0 using these instructions.
When I run 'fe40' appears the following:
Warning in ~foam/foam-extend-4.0/etc/config/settings.sh:
MPI_ROOT not a valid mpt installation directory or ending in a '/'.
Please set MPI_ROOT to the mpt installation directory.
MPI_ROOT currently set to ''
I suppose that is because I have installed the intel compiler. Where and what I must to change to compile foam-extend?
ramrebol is offline   Reply With Quote
Old   October 31, 2020, 19:59
Sebastian Engel
bluebase will become famous soon enough
H ranrebol,
I am not an experienced use regarding foam-extend.
However, i believe your executable asks for an environment variable set inside your shell/bash.
In case of bash, you could add the following command to your .bashrc file located in your home directory:
export MPI_ROOT=/path/to/mpiroot
where path/to/mpiroot should contain the executable mpirun in the subdirectory bin - or as absolute path: /path/to/mpiroot/bin/mpirun
At least according to: https://www.ibm.com/support/pages/me...riable-mpiroot
Then run: source ~/.bashrc or open a new terminal
To replace /path/to/mpiroot with the correct path you must identify which mpi libraries you have available on your system. Maybe contact your sysadmin, if it applies.
Best regards,
Sebastian
bluebase is offline   Reply With Quote
Old   November 2, 2020, 15:13
Ra Miro
Thanks Sebastian.
It seems that it was only a warning, because until now everything works without problems. But I will do the modification you suggest.
compilation, foam-extend 4.0, mpi
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 23:07
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
Sgimpi pere OpenFOAM 27 September 24, 2011 08:57
Error using LaunderGibsonRSTM on SGI ALTIX 4700 jaswi OpenFOAM 2 April 29, 2008 11:54
