[foam-extend.org] 4.1/4.0 Allwmake says cannot find -lfoam |
September 19, 2020, 05:30 |
Sultan Islam
Rep Power: 11 |
Dear all,
Hope everyone is doing well. While recompiling I did notice that there are a few errors that seem to be ignored but still makes me think If I am missing something? It says it cannot ld find -lfoam. I searched up and I already have the required library libz. Yet it still throws out the error? Is this something known and can be safely ignored or? Thanks Edit: Seems when i installed foam extend, these errors didn't show up. Idk if its a foam extend 4.1 issue, but for 4.0 the compilation worked! Last edited by EternalSeekerX; September 20, 2020 at 02:02. |
September 22, 2020, 06:02 |
Hrvoje Jasak
Rep Power: 33 |
You are missing the foam library. Try:
foamsrc wmake libso and see what is says. If everything is fine, it will re-link the library; otherwise your environment is not set up properly. Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
September 22, 2020, 06:16 |
I retried and it worked
Sultan Islam
Rep Power: 11 |
Hey thanks for the response. I was able to compile both foam extend 4.0 and 4.1 without any errors. However one issue is at least with foam extend 4.1 when using mpirun, it finishes the parallel run but mpirun still complains about termination process. Foam extend 4.0 doesn't do that for me in manjaro. Might be easier to run it on Ubuntu or Fedora. Please note that I had no issues compiling either esi or openfoam.com versions of openfoam.
How to make a code parallel? | Bruno Machado | Fluent UDF and Scheme Programming | 15 | May 27, 2016 10:18 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 01:52 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 13:38 |
Problem Building OF on Centos cluster (no admin rights) | CKH | OpenFOAM Installation | 5 | November 13, 2011 07:32 |
