[OpenFOAM.com] Current directory is not $WM_PROJECT_DIR???? |
August 14, 2020, 12:52 |
wangh
Rep Power: 6 |
I'm trying to install OpenFOAM-2.3.1 from source on Ubuntu 18.10 (I have installed the 7th version of OpenFOAM). When I try to launch ./Allwmake I get this error:
./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found Error: Current directory is not $WM_PROJECT_DIR The environment variables are inconsistent with the installation. Check the OpenFOAM entries in your dot-files and source them. please help me solve this problem,thank you very much!!! |
September 7, 2020, 10:28 |
#2 | |
Mark Olesen
Rep Power: 40 |
With these older versions you need to pay particular attention to the contents of the OpenFOAM etc/bashrc to ensure that directory location is correct (you probably need to manually edit the file). After making those changes and sourcing the etc/bashrc file, check that the value of "$WM_PROJECT_DIR" makes sense. Note that with such an old version of OpenFOAM, you are very likely to run into various compilation issues with newer compilers. |
installation, multiple version, openfoam |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 17:05 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 24, 2012 00:41 |
