[OpenFOAM.com] Install v2006 on macOS Mojave failed
Like Tree1Likes
Old   September 20, 2021, 08:02
Miguel Hernandez
Miguel Hernandez is on a distinguished road
Originally Posted by federico.carminati View Post
Did you delete all your previous tries from disk? Best
I thought I did it, I deleted the openFoam's folders I've created before, and the old images... Maybe it's not enough.
Is there a command to clear evertihing in order to restart from the beginning?
Miguel Hernandez is offline   Reply With Quote
Old   September 25, 2021, 07:30
Miguel Hernandez
Could my difficulties related to the M1 processor which is Arm and not x86?
Old   October 9, 2021, 06:49
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by Miguel Hernandez View Post
Thank you! To be honest, is too difficult to me... i’ve tried several times, but nothing....
I found that docker for M1 SoC works, but openFoam image is always emulated, and so is very very slow...
I don’t know what to do....
The emulation mode indeed is pretty slow since the dockerhub images are x86_64 Ubuntu. Supporting Arm64 Ubuntu is a bit of a problem (painfully slow package builds), but you can easily create your own local docker image fairly quickly.
We supply all of the docker files and resource files here:
https://develop.openfoam.com/packaging/containers
You will want to create an image using the openSUSE packages. This is described in the corresponding file
https://develop.openfoam.com/packagi...eap-Dockerfile
After running docker build on this, you can either tag it with the "opencfd/.." prefix so that the openfoam-docker script finds it, or run the openfoam-docker with -image=<your-image>
olesen is offline   Reply With Quote
Old   October 10, 2021, 16:21
Miguel Hernandez
Thank you Olsen, i did what you suggested... it works much better! Thanks
Old   October 17, 2021, 21:22
Tatsuya Shimizu
LongGe is on a distinguished road
Hello All
The reason for this error is that "feexceptErsatz.H" refers to the x86_64 structure of fenv.h. "feexceptErsatz.H" needs to be rewritten so that it uses the arm64 structure.
Here is how I built it, for your reference.
https://ttsyshmz.github.io/howtoFoam...2106-on-m1mac/
olesen likes this.
LongGe is offline   Reply With Quote
Old   October 18, 2021, 03:51
Miguel Hernandez
Hi Federico, yes I did...
But, is your Mac equipped with an M1 SoC or with a x86 cpu?
In another post, a forum member suggested this:
"You'll need to remove the sigfpe part(seems like Apple silicon doesn't support this feature?) then it should compile.
https://github.com/mrklein/openfoam-...ment-850090915 "
But I don't know exactly what this means...
Old   October 18, 2021, 04:12
Mark Olesen
Originally Posted by LongGe View Post
Hello All
Nice! I have added a corresponding issue for updating the upstream.
Old   October 22, 2021, 17:05
Domenico Lahaye
dlahaye is on a distinguished road
Following the wonderful advice of LongGe and Federico, I managed to install OpenFoam-v2106 on Mac M1!
In a final step, I need to define LD_LIBRARY_PATH to set the path to the third party libraries. How do I do so?
Thx!
dlahaye is offline   Reply With Quote
Old   October 24, 2021, 10:00
Domenico Lahaye
Update:
Various of the third party packages fail compile with Clang version 12.0 on Darwin. I failed to see this earlier. (Switch to gcc on Darwin is not supported).
E.g. scotch fails to compile due to the gettimneoftheday function being implicitly declared in src/libskotch/conmon.c. I was not yet able to turn this error of using -Wno-error=implicit-function-declaration.
Kahip fails due to the compiler not finding misc/omp.h . I was not yet able to extern the include directory with this path.
Metis does compile after manual download and installation of cmake using brew.
I am currently trying to run decomposePar using Metis. After installation LD_LIBRARY_PATH remains empty. Setting LD_LIBRARY_PATH manually does not cure the issue.
Old   October 24, 2021, 18:23
Tatsuya Shimizu
Hello All
In my case, I installed the third party with brew. As described here.
https://github.com/mrklein/openfoam-...ster/README.md
Old   October 25, 2021, 04:20
Domenico Lahaye
Further updates:
(1/3): good news: I managed to install Cmake using brew, to download Metis from the repository, to install Metis, to set DYLD_LIBRARY_PATH (observe MAC-OS convention) manually and to run decomposePar to obtain a decomposition. So far, so good.
(2/3): first question: A parallel run of simpleFoam fails, that is, "mpirun -np 4 simpleFoam -parallel" returns with "The dummy Pstream library cannot be used in parallel mode". The same issue however was however reported e.g. here https://develop.openfoam.com/Develop.../-/issues/1970. Will need to give it a look.
(3/3): second question: the compilation of the third party mesher cfMesh using Clang fails. I will give specifics in a next update.
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 04:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 16:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 11:58
