[OpenFOAM.com] OpenFOAM-2.3.1 cannot compile on Centos8
Old   July 23, 2020, 01:24
Default OpenFOAM-2.3.1 cannot compile on Centos8
YS
Ya_Squall2010 is on a distinguished road
I am trying to install the OpenFOAM-2.3.1 from source on the following platform: centos-release-8.2-2.2004.0.1.el8.x86_64. So far, I have succesfully installed from source the following OF versions: OpenFOAM-v2006, OpenFOAM-v1912, OpenFOAM-dev and foam-extend-4.1. The compilation of OpenFOAM-2.3.1 failed however. Any clue please?
The log file has been attached, many thanks!
Ya_Squall2010 is offline   Reply With Quote
Old   July 23, 2020, 01:51
YS
Executing /scratch/OpenFOAM/OpenFOAM-2.3.1/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: workstation
OS: Linux version 4.18.0-147.8.1.el8_1.x86_64
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /scratch/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /scratch/OpenFOAM/user-2.3.1 no no
$WM_THIRD_PARTY_DIR /scratch/OpenFOAM/ThirdParty-2.3.1 yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /scratch/OpenFOAM/OpenFOAM-2.3.1 yes yes yes
$FOAM_APPBIN ...-2.3.1/platforms/linux64GccDPOpt/bin yes yes yes
$FOAM_SITE_APPBIN .../2.3.1/platforms/linux64GccDPOpt/bin no no
$FOAM_USER_APPBIN ...-2.3.1/platforms/linux64GccDPOpt/bin no no
$WM_DIR /scratch/OpenFOAM/OpenFOAM-2.3.1/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...-2.3.1/platforms/linux64GccDPOpt/lib yes yes yes
$FOAM_SITE_LIBBIN .../2.3.1/platforms/linux64GccDPOpt/lib no no
$FOAM_USER_LIBBIN ...-2.3.1/platforms/linux64GccDPOpt/lib no no
$MPI_ARCH_PATH ...1/platforms/linux64Gcc/openmpi-1.6.5 yes yes yes
Third party software
Software Version Location
flex 2.6.1 /usr/bin/flex
gcc 8.3.1 /usr/bin/gcc
gzip 1.9 /usr/bin/gzip
tar 1.30 /usr/bin/tar
cmake 3.11.4
Old   September 7, 2020, 10:33
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
This is a really old (and unmaintained) version of OpenFOAM. In the meantime there have been many, many advances in compilers, which means that C++ constructs that were used in OpenFOAM and presumed to be standards-conform were not entirely.
olesen is offline   Reply With Quote
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
[OpenFOAM.org] Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS mukut OpenFOAM Installation 9 January 19, 2015 01:48
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
[swak4Foam] how to compile groovyBC to OpenFoam v1.6? tamsilian OpenFOAM Community Contributions 1 May 27, 2010 04:15
