[foam-extend.org] foam-extend-4.1 cannot compile on Centos8
Old   July 22, 2020, 02:27
Default foam-extend-4.1 cannot compile on Centos8
YS
Ya_Squall2010 is on a distinguished road
I am trying to install the foam-extend-4.1 from source code on the following platform: centos-release-8.2-2.2004.0.1.el8.x86_64. So far, I have succesfully installed from source the following OF versions: OpenFOAM-v2006, OpenFOAM-v1912, OpenFOAM-dev. The compilation of OF-extend-4.1 failed from the beginning however. Any clue please?
The log file is as follows:
make: Nothing to be done for 'all'.
This system rpm command: rpm
Starting ThirdParty Allwmake.pre
Starting ThirdParty AllMake: Stage1
Done ThirdParty AllMake: Stage1
Starting ThirdParty AllMake: Stage2
Building openmpi 1.8.8
Package name : openmpi-1.8.8
Package URL : https://www.open-mpi.org/software/om...i-1.8.8.tar.gz
RPM spec file name: openmpi-1.8.8.spec
RPM file name :
Additional flags : --define
Updating the ThirdParty environment variables before building package openmpi-1.8.8
RPM file name : /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/x86_64/openmpi-1.8.8-linux64GccDPInt32Opt.x86_64.rpm
Package openmpi-1.8.8 is already installed
Done installing package
Done ThirdParty AllMake: Stage2
Starting ThirdParty AllMake: Stage3
Building metis 5.1.0
Package name : metis-5.1.0
Package URL : http://downloads.sourceforge.net/pro...s-5.1.0.tar.gz
RPM spec file name: metis-5.1.0.spec
RPM file name :
Additional flags :
Updating the ThirdParty environment variables before building package metis-5.1.0
RPM file name : /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/x86_64/metis-5.1.0-linux64GccDPInt32Opt.x86_64.rpm
Package metis-5.1.0 is already installed
Building ParMGridGen 1.0
Package name : ParMGridGen-1.0
Package URL : http://downloads.sourceforge.net/pro...Gen-1.0.tar.gz
RPM spec file name: ParMGridGen-1.0.spec
RPM file name :
Additional flags :
Updating the ThirdParty environment variables before building package ParMGridGen-1.0
RPM file name : /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/x86_64/ParMGridGen-1.0-linux64GccDPInt32Opt.x86_64.rpm
Package ParMGridGen-1.0 is already installed
Building Libccmio 2.6.1
Package name : libccmio-2.6.1
Package URL : http://downloads.sourceforge.net/pro...o-2.6.1.tar.gz
RPM spec file name: libccmio-2.6.1.spec
RPM file name :
Additional flags :
Updating the ThirdParty environment variables before building package libccmio-2.6.1
RPM file name : /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/x86_64/libccmio-2.6.1-linux64GccDPInt32Opt.x86_64.rpm
Package libccmio-2.6.1 is already installed
Building Mesquite 2.3.0
Package name : mesquite-2.3.0
Package URL : https://software.sandia.gov/mesquite...e-2.3.0.tar.gz
RPM spec file name: mesquite-2.3.0.spec
RPM file name :
Additional flags :
Updating the ThirdParty environment variables before building package mesquite-2.3.0
RPM file name : /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/x86_64/mesquite-2.3.0-linux64GccDPInt32Opt.x86_64.rpm
Package mesquite-2.3.0 is already installed
Building Scotch 6.0.4
Package name : scotch-6.0.4
Package URL : http://downloads.sourceforge.net/pro...h_6.0.4.tar.gz
RPM spec file name: scotch-6.0.4.spec
RPM file name :
Additional flags :
Updating the ThirdParty environment variables before building package scotch-6.0.4
RPM file name : /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/x86_64/scotch-6.0.4-linux64GccDPInt32Opt.x86_64.rpm
Package scotch-6.0.4 is already installed
Building ParMetis 4.0.3
Package name : parmetis-4.0.3
Package URL : http://glaros.dtc.umn.edu/gkhome/fet...s-4.0.3.tar.gz
RPM spec file name: parmetis-4.0.3.spec
RPM file name :
Additional flags :
Updating the ThirdParty environment variables before building package parmetis-4.0.3
RPM file name : /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/x86_64/parmetis-4.0.3-linux64GccDPInt32Opt.x86_64.rpm
Package parmetis-4.0.3 is already installed
Building PyFoam 0.6.9
Package name : PyFoam-0.6.9
Package URL : https://files.pythonhosted.org/packa...m-0.6.9.tar.gz
RPM spec file name: PyFoam-0.6.9.spec
RPM file name : PyFoam-0.6.9-1.noarch
Additional flags :
Updating the ThirdParty environment variables before building package PyFoam-0.6.9
RPM file name : /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/noarch/PyFoam-0.6.9-1.noarch.rpm
Making package PyFoam-0.6.9 using RPM.
Building package PyFoam-0.6.9 using SPEC file : PyFoam-0.6.9.spec. Optional args:
Executing(%prep): /bin/sh -e /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/tmp/rpm-tmp.m2lM2Z
+ umask 022
+ cd /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/BUILD
+ rm -rf PyFoam-0.6.9
+ /usr/bin/gzip -dc /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/SOURCES/PyFoam-0.6.9.tar.gz
+ /usr/bin/tar -xof -
+ STATUS=0
+ '[' 0 -ne 0 ']'
+ cd PyFoam-0.6.9
+ /usr/bin/chmod -Rf a+rX,u+w,g-w,o-w .
+ exit 0
Executing(%build): /bin/sh -e /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/tmp/rpm-tmp.PBre33
+ umask 022
+ cd PyFoam-0.6.9
+ python setup.py build --executable '/usr/bin/env python'
/scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/tmp/rpm-tmp.PBre33: line 35: python: command not found
error: Bad exit status from /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/tmp/rpm-tmp.PBre33 (%build)
RPM build errors:
Installing package: PyFoam-0.6.9
Uninstalling PyFoam-0.6.9 using RPM: PyFoam-0.6.9-1.noarch
Installing PyFoam-0.6.9 using RPM file: /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/noarch/PyFoam-0.6.9-1.noarch.rpm
error: open of /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/noarch/PyFoam-0.6.9-1.noarch.rpm failed: No such file or directory
Building hwloc 2.0.1
Package name : hwloc-2.0.1
Package URL : http://www.open-mpi.org/software/hwl...c-2.0.1.tar.gz
RPM spec file name: hwloc-2.0.1.spec
RPM file name :
Additional flags :
Updating the ThirdParty environment variables before building package hwloc-2.0.1
RPM file name : /scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/rpmBuild/RPMS/x86_64/hwloc-2.0.1-linux64GccDPInt32Opt.x86_64.rpm
Package hwloc-2.0.1 is already installed
Done ThirdParty AllMake: Stage3
Starting ThirdParty AllMake: Stage4
Using system installed QT
Done ThirdParty AllMake: Stage4
Done ThirdParty Allwmake.pre
+ wmakePrintBuild -check
same version as previous build
+ wmakeLnInclude foam
+ wmakeLnInclude meshTools
+ wmakeLnInclude OSspecific/POSIX
+ wmake libo OSspecific/POSIX
SOURCE=signals/sigFpe.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/sigFpe.o
SOURCE=signals/sigSegv.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/sigSegv.o
SOURCE=signals/sigInt.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/sigInt.o
SOURCE=signals/sigQuit.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/sigQuit.o
SOURCE=regExp.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/regExp.o
SOURCE=timer.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/timer.o
SOURCE=fileStat.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/fileStat.o
SOURCE=POSIX.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/POSIX.o
SOURCE=clockTime/clockTime.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/clockTime.o
SOURCE=memInfo/memInfo.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/memInfo.o
SOURCE=multiThreader/multiThreader.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/multiThreader.o
SOURCE=fileMonitor.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/fileMonitor.o
SOURCE=printStack.C ; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/printStack.o
signals/sigFpe.C:26:10: fatal error: error.H: No such file or directory
#include "error.H"
compilation terminated.
POSIX.C:33:10: fatal error: OSspecific.H: No such file or directory
#include "OSspecific.H"
In file included from memInfo/memInfo.C:26:
memInfo/memInfo.H:41:10: fatal error: OSspecific.H: No such file or directory
In file included from multiThreader/multiThreader.C:36:
multiThreader/multiThreader.H:52:10: fatal error: error.H: No such file or directory
#include "error.H"
make: *** [signals/sigFpe.dep:7: Make/linux64GccDPInt32Opt/sigFpe.o] Error 1
make: *** Waiting for unfinished jobs....
make: *** [POSIX.dep:9: Make/linux64GccDPInt32Opt/POSIX.o] Error 1
make: *** [memInfo/memInfo.dep:8: Make/linux64GccDPInt32Opt/memInfo.o] Error 1
make: *** [multiThreader/multiThreader.dep:7: Make/linux64GccDPInt32Opt/multiThreader.o] Error 1
timer.C:30:10: fatal error: error.H: No such file or directory
#include "error.H"
clockTime/clockTime.C:27:10: fatal error: scalar.H: No such file or directory
#include "scalar.H"
make: *** [timer.dep:7: Make/linux64GccDPInt32Opt/timer.o] Error 1
printStack.C:26:10: fatal error: error.H: No such file or directory
#include "error.H"
signals/sigInt.C:27:10: fatal error: error.H: No such file or directory
#include "error.H"
signals/sigSegv.C:27:10: fatal error: error.H: No such file or directory
#include "error.H"
signals/sigQuit.C:27:10: fatal error: error.H: No such file or directory
#include "error.H"
make: *** [clockTime/clockTime.dep:7: Make/linux64GccDPInt32Opt/clockTime.o] Error 1
In file included from fileMonitor.C:26:
fileMonitor.H:46:10: fatal error: NamedEnum.H: No such file or directory
#include "NamedEnum.H"
In file included from fileStat.C:26:
fileStat.H:46:10: fatal error: label.H: No such file or directory
#include "label.H"
make: *** [printStack.dep:6: Make/linux64GccDPInt32Opt/printStack.o] Error 1
make: *** [signals/sigQuit.dep:7: Make/linux64GccDPInt32Opt/sigQuit.o] Error 1
make: *** [signals/sigSegv.dep:7: Make/linux64GccDPInt32Opt/sigSegv.o] Error 1
make: *** [signals/sigInt.dep:7: Make/linux64GccDPInt32Opt/sigInt.o] Error 1
make: *** [fileMonitor.dep:7: Make/linux64GccDPInt32Opt/fileMonitor.o] Error 1
make: *** [fileStat.dep:8: Make/linux64GccDPInt32Opt/fileStat.o] Error 1
regExp.C:29:10: fatal error: foamString.H: No such file or directory
#include "foamString.H"
make: *** [regExp.dep:7: Make/linux64GccDPInt32Opt/regExp.o] Error 1
+ set +x
Note: ignore spurious warnings about missing mpicxx.h headers
+ wmake libso foam
SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/4.1/' -e 's/BUILD_STRING/4.1-e2e049bb04c7/' $SOURCE > Make/linux64GccDPInt32Opt/global.C; g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/packages/openmpi-1.8.8/platforms/linux64GccDPInt32Opt/include -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OpenFOAM/lnInclude -I/scratch/OpenFOAM/OpenFOAM-extend-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c Make/linux64GccDPInt32Opt/global.C -o Make/linux64GccDPInt32Opt/global.o
make: *** [global/global.dep:253: Make/linux64GccDPInt32Opt/global.o] Interrupt
Ya_Squall2010 is offline   Reply With Quote
Old   July 22, 2020, 02:37
YS
basically I am following this post to compile:
https://openfoamwiki.net/index.php/I...end-4.1/CentOS
Old   July 22, 2020, 03:03
YS
Found solution...
The cause is that I changed the default installation folder name from 'foam' to 'OpenFOAM', and it leads to the result that the header files cannot be located properly. Kind of weired, right? After change the folder name back to 'foam', everything's fine.
[foam-extend.org] Foam Extend 4.0 compile on arm64 possible? EternalSeekerX OpenFOAM Installation 0 June 4, 2020 20:32
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." lethu OpenFOAM Meshing & Mesh Conversion 1 June 3, 2020 08:49
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
ParaView-4.0.1 did not compile for foam extend 3.0 installation mhkenergy OpenFOAM Installation 8 June 4, 2014 03:26
