[OpenFOAM.com] Error when compiling OpenFOAM.2.4.x
Old   June 23, 2020, 13:04
Exclamation Error when compiling OpenFOAM.2.4.x
Abhi Chopra
ChopraAbhi is on a distinguished road
Hi everyone,
I'm trying to compile OpenFOAM.2.4.x in x86_64 CentOS 7 system. I'm compiling this version because I need to run NREL/SOWFA version which is currently build for 2.4.x version or less only (https://github.com/NREL/SOWFA/blob/master/README.SOWFA). For compiling I followed the steps from here (https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL). I'm getting the following error during compilation.
error while loading shared libraries: libmpc.so.2: cannot open shared object file: No such file or directory
I used gcc/4.8.5 for this compilation. Can anyone help me with this error? Thank you in advance!
ChopraAbhi is offline   Reply With Quote
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer wildfire230 OpenFOAM Installation 20 May 6, 2020 08:30
Getting error both interpreting and compiling serene6390 Fluent UDF and Scheme Programming 1 October 27, 2017 01:49
All files present. but solver not compiling saddy OpenFOAM Programming & Development 1 July 29, 2017 10:50
[OpenFOAM.org] Trouble Compiling OpenFOAM-dev using Intel Compiler 15 for use on Xeon Phi foamer123 OpenFOAM Installation 9 August 20, 2015 15:03
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 06:40
