[Other] Use already compiled/installed Paraview with different OF versions |
May 24, 2020, 16:32 |
Luca
Rep Power: 15 |
Dear All,
I would like to understand if I need to install Paraview for each OF version or if I can always use the same OV installation. Let's make an example to clarify the point: - I installed OF 7 together with PV 5.6 - Now I want to install OF v1912 Can I use the same PV or should I compile it again? If I can use the same PV, how can I source it when I install OF v1912? Thank you in advance for your answer. Best, Luca |
Can different OpenFOAM versions share the same ParaView? | kiddmax | OpenFOAM Installation | 4 | July 23, 2021 10:20 |
[foam-extend.org] foam-extend-3.1 multiple versions paraview issue | CFDpal | OpenFOAM Installation | 1 | May 31, 2018 09:51 |
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release | FJSJ | OpenFOAM Installation | 2 | July 23, 2017 06:48 |
[Other] Which versions of OpenFoam and Paraview are suitable for Ubuntu 14.04 LTS Trusty Tahr | Asghari_M | OpenFOAM Installation | 4 | February 4, 2015 16:47 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
