May 12, 2020, 02:48 |
foam-extend 4.1
Ndong-Mefane Stephane Boris
Rep Power: 13 |
I have foam-extend 4.1 and openfoam v1906 installed on Ubuntu1804 (Windows subsystem). I'm also using aliases to switch between both environments. the ESI version works without any problem, but when I try to use anything in foam-extend, for example "blockMesh -help", I get the following error: Code:
--> FOAM FATAL ERROR: Could not find mandatory etc entry (mode=ugo) 'controlDict' I saw in a previous post by Wyldckat that this might happen when OF is installed in a directory containing spaces, but it is not the case. the command which foamExec gives: Code:
/opt/foam/foam-extend-4.1/bin/foamExec Thanks in advance for your help, Kazu |
May 26, 2020, 03:21 |
Same problem
Rep Power: 13 |
No one?
Is this Me? Covid-19? or the participation rate in the forum has been falling lately??? |
May 28, 2020, 10:40 |
kang seung-hwan
Rep Power: 6 |
I have same kind of problem. You foam-extend doesn't look that it was installed fully.
How was your installation process like? In my system, the installation wouldn't budge. |
June 2, 2020, 03:27 |
kang seung-hwan
Rep Power: 6 |
It may be because the extend version didn't run from source.
you can make another version into comment like below $vi ~/.bashrc (at almost last line) # source /opt/OpenFOAM/OpenFOAM-v1912/etc/bashrc and then $fe40 then run the case by extend version. And, I want to ask you, did you install 4.1 without any problem? Because I am trying to install extend 4.1 in ubuntu 18.04 LTS (WSL) but still having trouble. |
June 7, 2020, 06:25 |
Extend 4.1
#5 | |
Rep Power: 13 |
I installed version 4.1 without any obvious error or warning. Did you try doin an apt-get -update Before installing? The problem is the environment. I will try again with 4.0... |
March 3, 2021, 03:03 |
#6 | |
kang seung-hwan
Rep Power: 6 |
I'm using the extend-4.1 version now, too. My installation error was resolved after installing the WSL2. And it does not look that every solver works, but I have been figuring out. |
September 22, 2021, 02:01 |
Mesh problem in foam extent 4.0
Ammad
Rep Power: 5 |
Hello, I am trying to use foam extend 4.0. Can anyone please tell me if there is anyway to use OpenFOAM mesh on foam extent? because apparently the both use different mesh files. i cannot find any code to convert meshes. If anyone can help me in this regard?
November 10, 2021, 07:55 |
The same error
mohammad
Rep Power: 16 |
Hello everyone,
I have a PC a Foam Extend 4.0 has been installed on it by another person who does not know anything about OF. When I try to run OF, I get the following error, could you please help me to resolve this. Error .jpg |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 03:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
