[foam-extend.org] Foam-extend-4.0 compilation stuck at ThirdPary Stage 5
Old   April 15, 2020, 12:50
Default Foam-extend-4.0 compilation stuck at ThirdPary Stage 5
Stefania Zunino
stitch is on a distinguished road
I am trying to install foam-extend-4.0 on Ubuntu 18.04.4 LTS. I have followed these guidelines
https://openfoamwiki.net/index.php/I...om_source_code and
https://openfoamwiki.net/index.php/I...end-4.0/Ubuntu.
Unfortunately, when compiling I did not save the log file, but attached is a screenshot of the error message I am getting. I seems the compilation is stuck at Stage 5 - when installing swak4Foam? - of the ThirdParty installation process.
I have tried to run icoFoam on a tutorial and it works, so I am not sure of what was correctly installed and what was not.
The same problem was reported in a previous thread, but was not solved: Problems on installing Foam-extend 4.0/ swak4Foam on ubuntu18.0.4
I would like to avoid problems in the future and know everything was at least installed correctly in the first place. I am new to OpenFoam and Ubuntu, so any help would be appreciated!
stitch is offline   Reply With Quote
foam-extend 4.0, swak4foam error, third party
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 6 June 24, 2024 04:17
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
[foam-extend.org] Fluid Structure Interaction Toolkit on foam extend 4.0 Bazinga OpenFOAM Installation 1 August 17, 2020 23:51
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
