[OpenFOAM.org] ELI5: use a different compiler when compiling from source |
April 7, 2020, 07:29 |
Alex
Rep Power: 49 |
Hi, I managed to compile a working OpenFOAM v7 version from source. However, I guess that the default gcc compiler (7.5) on my system was used while doing so.
I have a newer version of gnu compilers (9.2) installed on my system, accessible via gcc-9. Which changes do I need to make in order to use this newer version during compilation? Last edited by flotus1; April 7, 2020 at 07:41. Reason: confused sources |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 04:50 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 16:14 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
