[OpenFOAM.com] Installing and running Swak4Foam on 1912 docker
Old   March 30, 2020, 10:44
Default Installing and running Swak4Foam on 1912 docker
Hektor
hektorWartgard is on a distinguished road
Dear all,
I do not manage to get OF1912 to run together with the groovyBC boundary condition iusing the supplied the docker containers.
I am running the OF1912 docker on Windows 10. I would like to use the GroovyBC boundary conditions, so I downloaded the swak4FoamAndPyFoamDockerFile docker container from here.
I ran the installation script in the docker terminal, and launched it using the launch script. It launches with the following messages appearing:
$ ./startSwakPyFoam
./startSwakPyFoam: line 12: xhost: command not found
of_v1912_plus_swak
/usr/bin/id: cannot find name for user ID 1072466
 [I have no name!@3c7e170bd1c5 hewa]$
I can access my working directory and run the standard solvers, as well as using groovyBC. However I cannot use my custom apps and boundary conditions.
The solvers are simple to fix, I just copy my binary to the working folder, and run it from there. This seems however not to work with the BC's.
$ ls
 0  0_orig  VTK  clean  constant  dynamicCode  myBC.so  myIcoReactingMultiphaseInterFoam  system
$ ./myIcoReactingMultiphaseInterFoam
--> FOAM FATAL IO ERROR:
Unknown patchField type myBC for patch type patch
Furthermore I cannot compile the BC's as I do not have access to the $FOAM_USER_LIBBIN & $FOAM_USER_APPBIN. See for example when I run wmake on my solver:
[I have no name!@3c7e170bd1c5 myIcoReactingMultiphaseInterFoam]$ wmake
g++ -std=c++11 -m64 -DOPENFOAM=1912 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3  -DNoRepository -ftemplate-depth-100 -I./phasesSystem/lnInclude -I./CompressibleMultiPhaseTurbulenceModels/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/fvOptions/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/meshTools/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/sampling/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/transportModels/compressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/TurbulenceModels/compressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/transportModels/interfaceProperties/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/thermophysicalModels/radiation/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/thermophysicalModels/basic/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/thermophysicalModels/specie/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/thermophysicalModels/reactionThermo/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1912/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/myIcoReactingMultiphaseInterFoam.o -L/opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/lib \
    -lfiniteVolume -lfvOptions -lmeshTools -lsampling -lturbulenceModels -lcompressibleTurbulenceModels -lcompressibleTransportModels -lradiationModels -lfluidThermophysicalModels -lIncompressibleMultiphaseSystems -lCompressibleMultiPhaseTurbulenceModels -lmassTransferModels -lsolidThermo -lsolidSpecie -ltwoPhaseProperties -llaserDTRM -lOpenFOAM -ldl  \
     -lm -o /opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin/myIcoReactingMultiphaseInterFoam
/usr/bin/ld: cannot open output file /opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin/myIcoReactingMultiphaseInterFoam: Permission denied
collect2: error: ld returned 1 exit status
 make: *** [/opt/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin/myIcoReactingMultiphaseInterFoam] Error 1
Do you have any suggestions on how to run my custom solver, BC and GroovyBC together?
Some observations that may, or may not, be of relevance:
  • of_v1912_plus_swak
    • Runs in docker quick start terminal
    • user is "I have no name!"
    • $FOAM_USER_APPBIN was wrongly set to
      //OpenFoam/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin
      I corrected this to:
      /opt/OpenFoam/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin
  • of_v1912
    • Runs in powershell
    • user is ofuser
    • $FOAM_USER_APPBIN
    • $FOAM_APP_BIN is set to
      /home/ofuser/OpenFOAM/ofuser-v1912/platforms/linux64GccDPInt32Opt/bin
I don't quite grasp how the docker environments work, so I might have missed something very basic. Any help is appreciated!
Best regards
Hektor
hektorWartgard is offline   Reply With Quote
Old   April 2, 2020, 17:42
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Dont know the answer to your question, I'm afraid. Yet I want to take this chance to highlight the fact that most of the functionalities of swak4Foam has been implemented into OFv1912 by converting from swak4Foam:
New expressions syntax.
HPE is offline   Reply With Quote
Old   April 7, 2020, 04:35
Hektor
That is interesting, thank you.
Old   May 25, 2021, 14:00
Exclamation swak4foam could not be installed on the cluster
kimy
qi.yang@polimi.it is on a distinguished road
Send a message via ICQ to qi.yang@polimi.it Send a message via AIM to qi.yang@polimi.it Send a message via Yahoo to qi.yang@polimi.it
Hi, could you please help me to see how to solve this issue since I tried many ways, really appreciated it.
/cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++:5: /cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW: No such file or directory
make: *** No rule to make target `/cineca/prod/opt/applications/openfoam+/v1912/intelmpi--2018--binary/OpenFOAM-v1912+/wmake/rules/linux64Gcc/c++OptBDW'.  Stop.
wmake error: file 'Make/linux64IccDPInt32OptBDW/sourceFiles' could not be created in /galileo/home/userexternal/qyang001/OpenFOAM/qyang001-v1912/swak4Foam/Utilities/makeAxialMesh
In the user's lib, it includes already following src:
libEulerianInterfacialSedModels.so
libEulerianPpSedModels.so
libgranularRheologySedModel.so
libgroovyBC.so
libgroovyStandardBCs.so
libkineticTheorySedModel.so
libmyturbulenceModels.so
libsimpleCloudFunctionObjects.so
libsimpleFunctionObjects.so
libsimpleLagrangianFunctionObjects.so
libsimpleRegionSolvers.so
libsimpleSearchableSurfaces.so
libsimpleSwakFunctionObjects.so
libswak4FoamParsers.so
libswakChemistryModelFunctionPlugin.so
libswakCloudFunctionObjects.so
libswakCoalCloudAdaptor.so
libswakDynamicMeshFunctionPlugin.so
libswakDynamicMesh.so
libswakFacSchemesFunctionPlugin.so
libswakFiniteArea.so
libswakFunctionObjects.so
libswakFvcSchemesFunctionPlugin.so
libswakFvOptions.so
libswakGeneralLanguageIntegration.so
libswakLagrangianCloudSourcesFunctionPlugin.so
libswakLagrangianParser.so
libswakLocalCalculationsFunctionPlugin.so
libswakLuaIntegration.so
libswakMeshQualityFunctionPlugin.so
libswakMeshWaveFunctionPlugin.so
libswakMRFFunctionPlugin.so
libswakPython3Integration.so
libswakPythonIntegration.so
libswakQuantileFunctionPlugin.so
libswakRadiationModelFunctionPlugin.so
libswakRandomFunctionPlugin.so
libswakScriptableLagrangian.so
libswakShiftFieldFunctionPlugin.so
libswakSourceFields.so
libswakStateMachine.so
libswakSurfacesAndSetsFunctionPlugin.so
libswakThermoTurbFunctionPlugin.so
libswakTopoSources.so
libswakTransportTurbFunctionPlugin.so
libswakVelocityFunctionPlugin.so
libtwoPhaseModel.so
libtwoPhaseTurbulenceModels.so
qi.yang@polimi.it is offline   Reply With Quote
docker, installataion, openfoam1912, swak4foam
[Other] Basic questions about OpenFOAM cluster running and installing Fauster OpenFOAM Installation 0 May 25, 2018 16:00
[swak4Foam] Installing swak4Foam 0.4.0 on ubuntu 14.04 JFM OpenFOAM Community Contributions 1 October 30, 2016 10:43
[swak4Foam] Installing swak4Foam on ubuntu 12.04 fluidflowsteel OpenFOAM Community Contributions 1 June 28, 2016 15:02
[swak4Foam] foam-extend-3.2 installing problem: swak4Foam failed to install due to Bison lxwd OpenFOAM Community Contributions 1 March 20, 2016 17:03
[swak4Foam] Error installing swak4Foam 0.2.3 on OF 2.2.2 Mojtaba.a OpenFOAM Community Contributions 2 December 7, 2013 04:32
