[OpenFOAM.com] OpenFoam installation failure with g++ internal compiler error
Old   March 20, 2020, 17:45
Default OpenFoam installation failure with g++ internal compiler error
WY
WUYing is on a distinguished road
I installed OpenFOAM7 on Ubuntu 18.04.4 virtual machine on MacOS 10.14.6, following the instructions from
https://openfoamwiki.net/index.php/I...7/Ubuntu/18.04.
However, when I finished compiling OpenFOAM and inputed "icoFoam -help", there appears an error saying "Command 'icoFoam' not found, but can be installed with: sudo apt install openfoam".
So I checked the log.make file, which had two errors:
g++: internal compiler error: killed (program cc1plus)
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-7/README.Bugs> for instructions.
/home/ying/OpenFOAM/OpenFOAM-7/wmake/rules/General/transform:25: recipe for target '/home/ying/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/src/thermophysicalModels/chemistryModel/chemistrySolver/chemistrySolver/makeChemistrySolvers.o' failed
make: *** [/home/ying/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/src/thermophysicalModels/chemistryModel/chemistrySolver/chemistrySolver/makeChemistrySolvers.o] Error 4
How can I solve this problem? Thanks!
WUYing is offline   Reply With Quote
Old   April 2, 2020, 17:46
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
OF7 is not openfoam.com version.
HPE is offline   Reply With Quote
g++, installation, internal compiler error, openfoam
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
[swak4Foam] swak4foam openfoam 7 installation problem Andrea23 OpenFOAM Community Contributions 1 February 17, 2020 19:11
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 19:07
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
