[OpenFOAM.org] Installation error for OF/5.x: ld.gold: error: --add-needed is not supported
Old   March 13, 2020, 10:13
Default Installation error for OF/5.x: ld.gold: error: --add-needed is not supported
Ehsan Moravveji
EhsanVSC is on a distinguished road
Dear all
I am trying to install OpenFOAM/5.x using OpenMPI/2.1.2-GCC-6.4.0 on our cluster for a specific user. Our machines are Intel SkyLake/CascadeLake generations running on CentOS 7.6.
All dependencies are loaded as modules in the build script (attached). I also set various env. vars. to point at the specific installation folders of the dependencies, to ensure that the build procedure finds them properly; but, I have two issues during the build:
  1. The CGAL and METIS are not found, though they are loaded. For MESTIS, I even set an env. var. pointing at the top installation folder:
    module load CGAL/4.11.1-foss-2018a-Python-3.6.4
    module load METIS/5.1.0-foss-2018a #-32bitIDX
    export METIS_ARCH_PATH=$EBROOTMETIS
    Not sure, if there exists a similar env. var. for CGAL? Nevertheless, the installation continues until the 2nd issue below
  2. After few minutes, I get the following error message:
    /myApps/software/binutils/2.28-GCCcore-6.4.0/bin/ld.gold: error: --add-needed is not supported but is required for libPstream.so in /myData/easybuild/work/OpenFOAM/from-source/OpenFOAM-5.x/platforms/linux64GccDPInt64Opt/lib/libOpenFOAM.so
    collect2: error: ld returned 1 exit status
    make: *** [/myData/easybuild/work/OpenFOAM/from-source/OpenFOAM-5.x/platforms/linux64GccDPInt64Opt/lib/libfiniteVolume.so] Error 1
For the two above issues, I am reaching out to you, and would like to know if you have already seen this before? And how to remedy this?
I have attached a compressed file containing the build script, and the stdout/stderr during the installation.
Kind regards
Ehsan
EhsanVSC is offline   Reply With Quote
--add-needed, cgal, metis
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 13:39
[OpenFOAM.org] problems with installation of OpenFOAM-2.1.1 on cluster with RHEL 6.5 lisa_china OpenFOAM Installation 1 March 29, 2016 09:08
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
[swak4Foam] Installing swak4Foam to OpenFOAM in mac Kaquesang OpenFOAM Community Contributions 22 January 21, 2013 12:51
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
