[OpenFOAM.com] "pvpython" working from command line, but not from of240 shell environment |
February 18, 2020, 06:07 |
Stu
Rep Power: 10 |
I installed pvpython with the hope of being able to use fabulous pyFoam tools like pyFoamPVSnapshot.py.
If I open new terminal window and type: Code:
pvpython --help However, if I open new terminal window and initialise OpenFOAM 2.4.0 shell environment first: Code:
of240 pvpython --help Code:
Executing PVSnapshot with pvpython through a proxy-script options: Error: Return code -11 executing /tmp/pyFoamPVSnapshot_DuBCZd.py –––––––––––––– Info: I am running OpenFOAM 2.4.0 and ParaView 4.1.0 on Ubuntu 16.04. Last edited by fluidstu; February 18, 2020 at 11:12. |
February 18, 2020, 16:47 |
Herpes Free Engineer
Rep Power: 12 |
Does PyFoam still support 2.4?
Why do u still use such an old version? I was vitamin D in an apple when they've released 2.4.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 19, 2020, 01:33 |
Stu
Rep Power: 10 |
February 19, 2020, 17:37 |
Rep Power: 12 |
No, Im afraid. Yet I believe I gave the best advice.
Hope you solve your problem.
February 20, 2020, 03:14 |
#5 | |
Stu
Rep Power: 10 |
Anyone want to address the original question? Last edited by fluidstu; February 20, 2020 at 05:33. |
February 20, 2020, 11:45 |
Rep Power: 12 |
Its engine is based on 2.x - which was first released in 2011 - and developed throughout 2010. What you don't understand is there is a reason why the version 3.0 was called 3.0, but not 2.5, as it underwent huge change.
>> only offered incorrect, snarky comment. Sorry, I should have not done that. But, you are right, unfortunately.. I'm sorry..
error, of240, pvpython |
[OpenFOAM.com] Setting of working environment in Ubuntu / WSL | christoph81 | OpenFOAM Installation | 3 | March 16, 2024 15:28 |
[Other] Fish shell environment configuration for OpenFOAM | francois | OpenFOAM Installation | 2 | October 22, 2015 16:37 |
[General] VTK API: Working with values inside the python shell | Thoma | ParaView | 4 | January 10, 2013 14:35 |
Setting working environment variable | Arthur | FLUENT | 0 | December 10, 2008 04:33 |
Debate on Working Environment | Debate | Main CFD Forum | 11 | December 19, 2000 23:21 |
