[Other] Difficulties to compile aerosolved in openfoam 1712, 1912
Like Tree6Likes
Old   February 3, 2020, 03:10
Default Difficulties to compile aerosolved in openfoam 1712, 1912
parth
parthigcar is on a distinguished road
Hello, foamers,
I am quite new to OpenFoam. I learned to run a few example cases. For my work, aerosol dynamics is necessary. This is provided by aerosolved (aerosolEulerFoam solver). The link for aerosolved is as below:
https://github.com/pmpsa-cfd/aerosolved
I tried to compile the program however, following two lines of Allwmake is creating errors:
wmake libso libraries/aerosolThermo
wmake libso libraries/aerosolModels
Initially, I thought it might be the OpenFoam version, so I downgrade from 1912 to 1712. However, still, I am getting similar errors. I have attached the error log. I am having really hard time what it hash table pointer.
parthigcar is offline   Reply With Quote
Old   February 6, 2020, 10:01
EdoF is on a distinguished road
The current 2.0 version of AeroSolved only compiles against OpenFOAM-v1812 and OpenFOAM-v1906. You were unlucky with your choice of OpenFOAM versions ;-)
Soon we will release version 2.1 which will probably support also OpenFOAM Foundation versions. You can follow the AeroSolved developments at Github.
francescomarra likes this.
EdoF is offline   Reply With Quote
Old   February 6, 2020, 22:39
parth
Hi, Thank you for your reply. I tried with OpenFOAM-v1812 now I am able to compile.
Old   February 7, 2020, 13:59
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Hey EdoF,
Why don't you release "aerosolved" as a submodule in OpenFOAM? Which would be win-win for users and your software?
Recently OpenQBMM is released as a submodule there.
I would just create a feature request in GitLab, the guys are pretty open and flexible in mind.
HPE is offline   Reply With Quote
Old   September 19, 2020, 05:01
Piyush
Piyush25 is on a distinguished road
HI,
I am running OpenFoam v2006 using ubuntu bash in windows 10. I also downloaded Aerosolved from github and copied it in the OpenFoam file and installed it using "sudo make" command.
Now I'm currently trying to run a tutorial of Aerosolved (bent pipe) and while executing Allrun, it throws me an error.
Is it because I'm using the newest version of OpenFoam? Should I delete this version and install OpenFoam verision 1906?
Piyush25 is offline   Reply With Quote
Old   September 19, 2020, 13:13
Krapf is on a distinguished road
Yes, see section "Dependencies": https://github.com/pmpsa-cfd/aerosol...Chap1_About.md. There seems to have been no update since EdoF's post.
parthigcar and Piyush25 like this.
Krapf is offline   Reply With Quote
Old   September 20, 2020, 06:22
Piyush
Hi, I installed OpenFoam-v1906 on my Ubuntu 18.04 LTS (bash).
Now I'm getting a lot of errors while installing aerosolved. Please have a look...
piyush@LAPTOP-QSMI8GI5:/opt/OpenFOAM/OpenFOAM-v1906/aerosolved-master$ make
./Allwmake
./Allwmake: line 3: wmake: command not found
./Allwmake: line 5: wmakeLnInclude: command not found
./Allwmake: line 6: wmake: command not found
./Allwmake: line 8: wmake: command not found
./Allwmake: line 9: wmake: command not found
./Allwmake: line 11: wmake: command not found
Makefile:6: recipe for target 'compile' failed
make: *** [compile] Error 127
UPDATE: Same Installation problems also in ubuntu.
Old   September 20, 2020, 08:16
I'm not able to help you, but if you search the web for "wmake: command not found" you will find some hints.
Old   September 21, 2020, 07:40
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
./Allwmake
Please Help!
Try using a pre-compiled package for 1912 or 2006:
https://develop.openfoam.com/Develop...ompiled/debian
olesen is offline   Reply With Quote
Old   September 21, 2020, 13:09
Default Thanks for your help :)
Piyush
Hi guys,
I tried everything but nothing seems to work.
Now it is throwing me many fatal errors . One such errors is shown below:
/opt/OpenFOAM/ThirdParty-v1812/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/os_defines.h:39:22: fatal error: features.h: No such file or directory.
Lastly, I guess this is because I'm using Ubuntu bash in Windows 10. I might switch to linux.
Old   October 3, 2020, 14:17
Default Allrun is unable to execute
  #11
Piyush
When we try to execute the Allrun script using the command :
./Allrun fullStokes sectional
The script is throwing the syntax error issue. I Tried to remove the if condition and directly kept the value present in else condition, removed if else condition itself then also did not work properly.
Can You kindly confirm why the shell script is unable to run.
piyush@LAPTOP-QSMI8GI5:~/OpenFOAM/piyush-v1812/aerosolved/cases/bentPipe_BC$ ./Allrun fullStokes sectional
./Allrun: 19: ./Allrun: Syntax error: "(" unexpected (expecting "then")
piyush@LAPTOP-QSMI8GI5:~/OpenFOAM/piyush-v1812/aerosolved/cases/bentPipe_BC$ ^C
Old   October 6, 2020, 12:14
Mark Olesen
I took a quick look and made a few changes to compile with OpenFOAM-v2006, should also work with slightly older versions
Here is the merge request: https://github.com/pmpsa-cfd/aerosolved/pull/3
Also took a very quick look at some of the Allrun scripts, seeing as at least one user reported problems. As far as I can see there are no intrinsic issues, but many of the scripts to expect additional arguments for input. If these are missing you will see a script syntax errors. The scripts could be made more robust, but for now you will have to read them to see if you are using them as the developer expected.
parthigcar and Melbournite like this.
Old   October 7, 2020, 02:01
parth
@olesen, yes, I have tested for 1906, it was working. Also, the allrun scripts for the bend pipe are working fine.
Old   October 7, 2020, 05:14
Default Condensation Model
  #14
Piyush
I somehow got aerosolved working and bentPipe is working fine too. Thanks for the guidance
Now i want to model condensation.
So in aerosolProperties, i changed the condensation model from none to coupled.
submodels
condensation
type coupled;
nucleation
type none;
coalescence
type none;
driftFluxModel
diffusion
type none;
Brownian
type StokesEinstein;
inertial
type fullStokes;
tolerance 1E-6;
maxIter 3;
VMax 10.0;
NO OTHER CHANGES ARE MADE in any files
Getting some errors:
[7] --> FOAM FATAL IO ERROR:
[7] Entry 'activityCoeff' not found in dictionary "IOstream.submodels.condensation"
[7]
[7] file: IOstream.submodels.condensation
[7]
[7] From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const
[7] in file db/dictionary/dictionary.C at line 476.
[7]
FOAM parallel run exiting
Does anyone know what is the problem??
Old   October 7, 2020, 06:47
parth
@Piyush, there is no problem in the code. You are not defining sufficient parameter required for that option.
This message means you have not defined activityCoeff in the dictionary condensation.
Old   October 7, 2020, 08:16
  #16
Piyush
Ok, Sir.
Can you suggest any good documentation on aerosolved? The documentation they provided in github contains very little information, I feel.
Thank you
Old   November 3, 2020, 10:51
Default problem with thermotype in BentPipe (AeroSolved)
  #17
Piyush
Hi, I'm also trying to run aerosolved in different PC and all the tutorial cases run fine but there is a problem with bentPipe case. When I tried to run the default case, the following error is shown:
[1] --> FOAM FATAL ERROR:
[1] Unknown rhoAerosolPhaseThermo type
thermoType
type heAerosolRhoThermo;
mixture aerosolPhase;
transport const;
thermo hConst;
energy sensibleInternalEnergy;
equationOfState perfectGas;
specie specie;
Valid rhoAerosolPhaseThermo types are:
heAerosolRhoThermo aerosolPhase const eConst incompressiblePerfectGas specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase const eConst perfectGas specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase const hConst icoFunction specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase const hConst icoPolynomial specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase const hConst perfectFluid specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase const hConst rhoConst specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase polynomial hPolynomial icoPolynomial specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase sutherland janaf adiabaticPerfectFluid specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase sutherland janaf incompressiblePerfectGas specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase sutherland janaf perfectFluid specie sensibleInternalEnergy
heAerosolRhoThermo aerosolPhase sutherland janaf perfectGas specie sensibleInternalEnergy
[1]
[1]
[1] From function static typename Table::iterator Foam::basicThermo::lookupThermo(const Foam::dictionary&, Table*, std::initializer_list<const char*>, const Foam::word&) [with Thermo =$
[1] in file /home/thaseem/OpenFOAM/OpenFOAM-v1906/src/thermophysicalModels/basic/lnInclude/basicThermoTemplates.C at line
PS: I don't have this error on my other PC. I tried other rhoAerosolThermoTypes as it suggested but doesn't work. Help needed. Thank you!
cfdGeek likes this.
Old   December 22, 2020, 04:01
Smile Same problem happened
  #18
Victor
VictorOpen is on a distinguished road
I also met same problem with you.
thermoType
transport const;
thermo hConst;
specie specie;
I'm useing openfoam 1906 version.
Before installing version 1906, I used openfoam 1812. It does not have this problem under openfoam 1812.
I also do not know how to solve it.
Does anybody have some suggestion? Thank you very much.
VictorOpen is offline   Reply With Quote
Old   December 22, 2020, 04:21
parth
Have you tried to clear the environment? before using other version OpenFOAM environment you should clear the environment by using 'unset' command
Old   December 22, 2020, 04:22
parth
I have used aerosolved with 1812 only.
aerosolved, compilation error, compile error, openfoam 1712, openfoam 1912
Combustion modelling in OpenFOAM - Difficulties AleDR OpenFOAM Running, Solving & CFD 23 January 31, 2021 00:40
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
[Other] Difficulties trying to install porousMultiphaseFoam on OpenFOAM for Windows 15.06 JKoeleman OpenFOAM Community Contributions 0 September 15, 2015 10:36
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
