[Other] Issues installting foamCalcEx on OF6
Old   January 1, 2020, 20:12
Default Issues installting foamCalcEx on OF6
X
mcfdma is on a distinguished road
So I want to use volIntegrate using foamCalcEx (installation - https://openfoamwiki.net/index.php/C...alcEx#Download)
when I try to ./Allwmake I am getting an error:
I referred to Error making a new utility code: "cyclicAMILduInterface.H: No such file or directory"
where I included
EXE_INC = \
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/triSurface/lnInclude \
    -I$(LIB_SRC)/surfMesh/lnInclude \
    -I$(LIB_SRC)/fileFormats/lnInclude
LIB_LIBS = \
    -ltriSurface \
    -lsurfMesh \
    -lfileFormats
in src/meshTools/Make at the top suggested on the same thread (i.e. to put it first)
At meshTools, I wclean as per wmake error: file 'Make/linux64Gcc44DPOpt/objectFiles' could not be created and followed by wmake, that's when I get the error.
Error
m@E-10DXX4FZ6352:~/OpenFOAM/m-6/foamcalcex$ ./Allwmake
~/OpenFOAM/m-6/foamcalcex/postProcessing ~/OpenFOAM/m-6/foamcalcex
+ wmake libo postCalc
wmake libo postCalc
+ wmake libso foamCalcFunctionsEx
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/home/m/OpenFOAM/OpenFOAM-6/src/finiteVolume/lnInclude  -IlnInclude -I. -I/home/m/OpenFOAM/OpenFOAM-6/src/OpenFOAM/lnInclude -I/home/m/OpenFOAM/OpenFOAM-6/src/OSspecific/POSIX/lnInclude   -fPIC -c calcType/calcType.C -o Make/linux64GccDPInt64Opt/calcType/calcType.o
In file included from /home/m/OpenFOAM/OpenFOAM-6/src/finiteVolume/lnInclude/ddtScheme.C:30:0,
                 from /home/m/OpenFOAM/OpenFOAM-6/src/finiteVolume/lnInclude/ddtScheme.H:357,
                 from /home/m/OpenFOAM/OpenFOAM-6/src/finiteVolume/lnInclude/fvcDdt.C:28,
                 from /home/m/OpenFOAM/OpenFOAM-6/src/finiteVolume/lnInclude/fvcDdt.H:250,
                 from /home/m/OpenFOAM/OpenFOAM-6/src/finiteVolume/lnInclude/fvc.H:44,
                 from /home/m/OpenFOAM/OpenFOAM-6/src/finiteVolume/lnInclude/fvCFD.H:8,
                 from calcType/calcType.H:48,
                 from calcType/calcType.C:26:
/home/m/OpenFOAM/OpenFOAM-6/src/finiteVolume/lnInclude/cyclicAMIFvPatch.H:39:35: fatal error: cyclicAMILduInterface.H: No such file or directory
 #include "cyclicAMILduInterface.H"
compilation terminated.
/home/m/OpenFOAM/OpenFOAM-6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt64Opt/calcType/calcType.o' failed
make: *** [Make/linux64GccDPInt64Opt/calcType/calcType.o] Error 1
Any help is appreciated.
mcfdma is offline   Reply With Quote
Old   January 2, 2020, 16:25
Tarang
gtarang is on a distinguished road
https://github.com/OpenFOAM/OpenFOAM...etc/caseDictsI think some hit and trial has to be done. Try removing all the other files and folders from your Make directory except files and options. And then wmake again. Sometimes i have faced these kind of problems for which I used this.
Other than that I think trying changing the order of lnInclude files.
PS: I think you can also use function object for your activity. Pls see if these folders are of any help
1. https://github.com/OpenFOAM/OpenFOAM...nObjects/field
2. https://github.com/OpenFOAM/OpenFOAM.../etc/caseDicts
gtarang is offline   Reply With Quote
Old   January 4, 2020, 12:01
X
I tried different ways but unfortunately none of them are successful so far.
In regards to removing other files and folders from Make directory, I have nothing else beside file and options.
Yes I had a look at the functionsObjects but couldn't find the ones I require:
1. volIntegrate (which is available using foamCalcEx https://openfoamwiki.net/index.php/Contrib_foamCalcEx)
2. magGrad (which is available using foamCalc Use of foamCalc)
Any other way to acquire those?
Old   January 4, 2020, 13:06
Tarang
Sorry I cannot help with compilation, after quick glance through the code at bitbucket, I can help you with magGrad utility.
postProcess -func "grad(T)"
postProcess -func "mag(grad(T))"
T is the variable name.
I check above code for OpenFOAM-6. I guess above code will work for OpenFOAM-5 onwards.
I couldn't get what volIntegrate is supposed to do. Can you explain a bit what you want to achieve through it?
Old   January 6, 2020, 04:59
X
Hi Tarang. Sorry for the late reply.
I realised the "mag(grad(T))" postProcess in another forum but thank you for helping me with that.
volIntegrate is volume integral of a field, in my case volumetric charge density.
I will try the volFieldValue function to see if I get the same results I acquired using foamCalcEx in OF231 or maybe try define operation volIntegrate .
Another way I found is including function in controlDict (volum integral of mag(U)...?)
will update which works with OF6.
foamcalcex, meshtools.h, of6, utilities
InterFoam: Different results in OF5 and OF6 vatavuk OpenFOAM Bugs 19 January 26, 2021 18:22
chtMultiRegionSimpleFoam issues - non-conformal meshes & residual handling... manalis OpenFOAM Running, Solving & CFD 3 October 10, 2018 19:53
Convergence issues for Flat plate with sharp edge rajnarayang FLUENT 3 June 20, 2017 13:02
[ANSYS Meshing] Multizone issues (on my project) crenaudo ANSYS Meshing & Geometry 8 April 13, 2016 03:59
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 17:18
