[OpenFOAM.org] OpenFOAM 2.3.1 on Ubuntu 16.04 |
December 1, 2019, 10:56 |
X
Rep Power: 7 |
Hi.
Trying to install OF231 on Ubuntu 16.04. I have previously installed it on Ubuntu 14.04 and was working well. However, 16.04 is giving me weird error. I have attached the log error. I tried following #3 from (Problems installing OpenFOAM 2.4.0 on Fedora 23) but not helpful. Any help will be appreciated. |
December 3, 2019, 14:04 |
X
Rep Power: 7 |
Same issue and I tried following Post #3 but still wmake fails.
OF 2.3.1 on Ubuntu 16.04 [Moderator note: Moved from Installing OpenFOAM-2.3.x] Last edited by wyldckat; December 3, 2019 at 16:33. Reason: see "Moderator note" |
December 3, 2019, 16:30 |
#3 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Furthermore, there are specific step-by-step installation instructions for the versions you stated: https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04 edit: I then went looking for past posts of yours and moved your post above to the original thread you started asking about this. Please be more specific about which installation instructions you've followed. If you have not tried the instructions from the link I've provided, please do so.
December 3, 2019, 19:17 |
X
Rep Power: 7 |
Apologies. I followed the steps provided in (https://openfoamwiki.net/index.php/I...u#Ubuntu_16.04) Section 2.6 Ubuntu 16.04.
I have attached the error log. I am able to install other version of OF (OF4.x, OF6). Not sure what I am doing incorrectly. |
December 4, 2019, 17:54 |
Herpes Free Engineer
Rep Power: 13 |
Is there any reason why you want to compile such an old OpenFOAM version? If might be related to a personal piece of code, we can try to modify it for you, so that you can compile the newest versions of OpenFOAM. Just saying.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 5, 2019, 05:25 |
X
Rep Power: 7 |
Hello HPE. Yes, I am working electrospray/electrohydrodynamic process. I have a modified solver on OF231 (interFoam with electric field component) which I am trying to verify with some experimental results. I am getting droplet production for organic solvents such as Triethylene glycol. But as I increase the conductivity, my simulation crashes.
So thought to make it work on the old version and then update it. If you can help me modify to newer version, that would be highly appreciated. Should I attach the solver here? |
openfoam 2.3.1, openfoam 2.3.x, ubuntu 16.04 |
[OpenFOAM.org] OpenFOAM 7 installation on ubuntu 16.04 LTS | kerim | OpenFOAM Installation | 2 | October 10, 2019 01:04 |
[OpenFOAM.org] OpenFOAM 5 source pack installation on Ubuntu 16.04 | CjjJoy | OpenFOAM Installation | 23 | June 6, 2018 11:55 |
[OpenFOAM.org] OpenFOAM 2.3.0 ubuntu 16.04 | FlyBob91 | OpenFOAM Installation | 5 | November 17, 2017 08:11 |
[OpenFOAM.org] OpenFOAM missing after upgrade to Ubuntu 16.04 | Storyteller | OpenFOAM Installation | 2 | May 1, 2016 19:14 |
[OpenFOAM.org] Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS | mukut | OpenFOAM Installation | 9 | January 19, 2015 01:48 |
