[OpenFOAM.com] Using surfaceautopatch in windows 10?
Old   November 28, 2019, 15:52
Default Using surfaceautopatch in windows 10?
Franco
otaolafr is on a distinguished road
hello,
i have followed the guide from openfoam.com to install OF in w10 (https://www.openfoam.com/download/in...windows-10.php)
everything okey and OF works, but i was trying to use surfaceAutoPatch,
it gave me the error that it wasnt installed, after installation,and re do the surfaceAutoPatch it gave me the following error:
surfaceAutoPatch: symbol lookup error: /usr/lib/libtriSurface.so: undefined symbol: _ZNK4Foam11regIOobject11writeObjectENS_8IOstream12 streamFormatENS1_13versionNumberENS1_15compression TypeE
anyhelp?
otaolafr is offline   Reply With Quote
Old   November 29, 2019, 12:33
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
What was the first error that led you to the re-installation? The second error might be related that the reinstallation is corrupted due to the lack of fresh start of installation (you might need to delete everything before the re-installation).
HPE is offline   Reply With Quote
Old   November 29, 2019, 13:28
Franco
hi!
thanks for answering me,
what I have done for the moment was to follow the instructions of installation from openfoam.com (https://www.openfoam.com/download/in...windows-10.php)
some other details:
when doing the instructions everything went okay (installed everything correctly and also run the case cavity)
after doing it, I tried to run paraFoam without success and after some reading I installed Xming and then paraFoam worked.
as I am learning, I found a tutorial where they used surfaceAutoPatch and as I want to use external STLs I thought it would be a great opportunity, I tried to use it and it told me that I didn't had it installed and then offered me to install it.
I installed (no error show up) and then when I tried again it showed that error.
also, another thing I found myself was that when I tried to use parametric blockMesh with internal calculations (with #calc) it also gives me an error (if I take out all the #calc blockMesh works perfectly...)
for the second error, I am pasting it at the end.
what I am really questioning my self (as I am not someone that has worked with Linux or that have done a lot of programming...) if it is a good idea to keep with the WLS to use OF or if i should install a virtual machine with Linux directly to not have any errors (another example is that I paste a folder in the explorer of windows in the same folder that the cavity example was created, from the installation, and I didn't have rights to read/write/execute the newly copied folder from the Ubuntu terminal)
the ubuntu that I installed was the one from the window store 18.04 LTS
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_32523b6657d9c45c007350f9a7929aec199259b9/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_32523b6657d9c45c007350f9a7929aec199259b9.so"
file: /mnt/c/Users/Microreactors/OpenFoam_Filles_Simulation/test_snappy/system/blockMeshDict
    From function static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
    in file db/dictionary/functionEntries/codeStream/codeStream.C at line 201.
FOAM exiting
thanks for the help, I am really new with OpenFOAM, and it is not easy to follow everything when at the same time you don't know a lot about computers...
Old   November 29, 2019, 13:47
HPE
HPE's Avatar
No worries.
I don't know how to even shut down a Windows computer, I'm afraid, so can't suggest anything about this.
Is there any chance for you to attach the error log file, so that I can chase it up for you in the medium term?
Old   November 30, 2019, 11:28
Franco
No worries.
LOL, well I guess that we are at the same place but in other sides of the "window"... As I don't even know how to recover an error file 😅 I only copy paste from the command line... 😅
Best regards
Old   December 4, 2019, 17:41
HPE
HPE's Avatar
I will chase it for you till next Monday since openfoam.com repos seem to be under maintenance. Bear with me please. Apologies for the delay.
Old   December 5, 2019, 09:18
Franco
thanks,
to dont have any more issues as some things i wasnt able to do with the windows version, i changed to a linux ubuntu machine for the moment i am not having any issue thanks a lot! (either way if you could teach me how i can copy a error file for next time i will appreciate it )
surfaceautopatch
Compile Fluent UDF with Windows 10 daniel_pramudita FLUENT 15 May 13, 2020 23:29
[OpenFOAM.com] v1712 with Docker on Ubuntu 17.10. Use same docker in Windows 10? amh@inventas.no OpenFOAM Installation 0 January 30, 2018 09:59
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
Dual Boot Windows and Linux and Go Open Source andyj Main CFD Forum 2 October 21, 2010 17:49
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
