[Other] gcc: error: unrecognized command line option ‘--showme:link’; did you mean ‘--force-l |
November 27, 2019, 06:53 |
Pushpender Sharma
I am trying to install openFoam-v6 on Ubuntu 18.04, but I get an error while following step 7 of the procedure given on https://openfoamwiki.net/index.php/I...nFOAM-6/Ubuntu, i.e. when I enter:
source $HOME/OpenFOAM/OpenFOAM-6/etc/bashrc WM_LABEL_SIZE=64 FOAMY_HEX_MESH=yes I get this error: gcc: error: unrecognized command line option ‘--showme:link’; did you mean ‘--force-link’? Please help. |
December 4, 2019, 17:01 |
Herpes Free Engineer
Rep Power: 13 |
Try OpenFOAM v1906 then, which has more functionalities anyways.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
January 6, 2021, 00:40 |
starter
Rep Power: 16 |
I am having this error after I have installed OpenFOAM 2012. Have you found a solution?
January 8, 2021, 14:18 |
Mark Olesen
Rep Power: 40 |
How did you "install" OpenFOAM?
The binary packages (Ubuntu, Redhat, opensuse) preconfigure the values, otherwise you need to have 'mpicc' available (eg, open-mpi devel package) |
openfoam-6, ubuntu 18.04 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
