[foam-extend.org] NEW: Installation guide for foam-extend 4.1 on OpenFoamWiki |
May 17, 2022, 00:54 |
#41 | |
Sultan Islam
Rep Power: 11 |
You could go into the thirdparty folder and edit allwmake.post to change swak4foam to the latest version (since it will be patched for missing HUGE type missing). Or just find the file its talking about in the gcc ouput inside the swak4foam folder and replace HUGE with GREAT. Run allwmake directly from the swak4foam folder and be on your way =) |
May 17, 2022, 09:14 |
#42 |
Mohammad Reza
Rep Power: 11 |
Thank you for the reply,
Which ThirdParty folder are you talking about? I found a ThirdParty folder under swak4Foam/releaseTesting/ThirdParty But this folder only contains a file centFOAM.py. P.S: I am trying to install swak4Foam in my home directory without root access. Regards, Mohammadreza |
May 18, 2022, 23:00 |
#43 | |
Sultan Islam
Rep Power: 11 |
foam/foam-extend-4.1/ThirdParty/rpmBuild/BUILD/swak4Foam-0.4.2/ Once you patch the unitCylinderSearchableSurface.c you can run Allwmake in that path and swak4foam will be configured. I installed both fe41 and all its thirdparty packages inside my home direction too. As long as foam extend bashrc is sourced, your swak4foam can be anywhere (as long as it links correctly) |
September 11, 2024, 09:48 |
#44 |
Rep Power: 4 |
How about Ubuntu 24 (noble), please?
Installation Guide for OpenFOAM-1.6-ext on Mac OS X Mountain Lion | BernhardGrieser | OpenFOAM Installation | 4 | October 26, 2013 16:39 |
OpenFOAM installation in SL 6.3 (guide req) | som87 | OpenFOAM Installation | 2 | September 27, 2012 18:21 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
can you please share STAR CD installation guide | Bhavani | Siemens | 1 | November 30, 2005 12:17 |
Fluent 5.5. What the differences with fluent 5.3?? | confused | FLUENT | 2 | July 29, 2001 22:58 |
