[OpenFOAM.com] Paraview doesnt build on Manjaro KDE |
Praphul T
Rep Power: 12 ![]() |
HI,
I use a Manjaro KDE 18.1.0 operating system. I was trying to compile the paraview from the Thirdparty folder of OpenFOAM-v1906. The build process always fails at 5%. I am not sure what I am doing wrong. I have attached the compilation log along this with post. This is the command I had tried Code:
./makeParaView -mpi=0 -python -gcc -mesa-prefix $WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER/mesa-17.1.1 -qt-5.13.1 -suffix mesa-mpi-py-qt 2>&1 | tee Compile_Paraview_Log.txt Any help on the same is appreciated. Regards, Praphul T |
build error, openfoam 1906, paraview 5.6.0 |
[OpenFOAM.org] Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped) | dslbkxd | OpenFOAM Installation | 1 | February 3, 2018 00:56 |
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release | FJSJ | OpenFOAM Installation | 2 | July 23, 2017 05:48 |
Hardware build review/advise for student desktop | AerE | Hardware | 10 | July 5, 2013 06:03 |
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? | lentschi | OpenFOAM Installation | 1 | March 9, 2011 02:32 |
Paraview not found | fusij | OpenFOAM Installation | 2 | January 1, 2011 20:44 |
