[OpenFOAM.com] Install OpenFOAM v1906 on a cluster with CentOS/RHEL 7 |
August 21, 2019, 02:37 |
zhenhai zhang
Rep Power: 7 |
Hey guys
I am trying to install the openFOAM on the university cluster and i have been following this link for reference. https://www.openfoam.com/download/install-source.php and every thing seems right until i run the command: foamInstallationTest and this is the error message displayed saying 'icoFoam not installed: (i apologize for the bad formatting of the post, it is actually my first post) Code:
Basic setup : ------------------------------------------------------------------------------- OpenFOAM: OpenFOAM-v1906 ThirdParty: ThirdParty-v1906 Shell: bash Host: monarch-login2 OS: Linux version 3.10.0-957.5.1.el7.x86_64 ------------------------------------------------------------------------------- Main OpenFOAM env variables : ------------------------------------------------------------------------------- EnvironmentVariable FileOrDirectory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_USER_DIR /home/zzha518/OpenFOAM/zzha518-v1906 no no $WM_THIRD_PARTY_DIR ...y81/zzha518/OpenFOAM/ThirdParty-v1906 yes yes ------------------------------------------------------------------------------- OpenFOAM env variables in PATH : ------------------------------------------------------------------------------- EnvironmentVariable FileOrDirectory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR .../ny81/zzha518/OpenFOAM/OpenFOAM-v1906 yes yes yes $FOAM_APPBIN ...06/platforms/linux64GccDPInt32Opt/bin no yes $FOAM_SITE_APPBIN ...06/platforms/linux64GccDPInt32Opt/bin no no $FOAM_USER_APPBIN ...06/platforms/linux64GccDPInt32Opt/bin no no $WM_DIR ...zzha518/OpenFOAM/OpenFOAM-v1906/wmake yes yes often ------------------------------------------------------------------------------- OpenFOAM env variables in LD_LIBRARY_PATH : ------------------------------------------------------------------------------- EnvironmentVariable FileOrDirectory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...06/platforms/linux64GccDPInt32Opt/lib yes yes yes $FOAM_SITE_LIBBIN ...06/platforms/linux64GccDPInt32Opt/lib no no $FOAM_USER_LIBBIN ...06/platforms/linux64GccDPInt32Opt/lib no no $FOAM_EXT_LIBBIN ...v1906/platforms/linux64GccDPInt32/lib yes yes maybe $MPI_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software Components ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- flex 2.5.37 /bin/flex wmake 1906 ...zha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/wmake/wmake gcc 4.8.5 /bin/gcc g++ 4.8.5 /bin/g++ gzip 1.5 /bin/gzip tar 1.26 /bin/tar icoFoam *** not installed *** CRITICAL ERROR ------------------------------------------------------------------------------- Summary ------------------------------------------------------------------------------- Base configuration ok. The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for troubleshooting. Done Thank you very much in advance!!!! Last edited by wyldckat; August 25, 2019 at 09:11. Reason: Added [CODE][/CODE] markers |
August 25, 2019, 09:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: In that page you provided, it gives a link to the Build page: https://www.openfoam.com/code/build-guide.php - did you follow the instructions given on that page?
August 26, 2019, 23:37 |
#3 | |
zhenhai zhang
Rep Power: 7 |
Hello Bruno Thanks for replying. Yes i follow everything on the build page and when i try the command 'foamSystemCheck' it says the following: Code:
bash: foamSystemCheck: command not found... Code:
bash: mpicc: command not found... No completion added for /home/zzha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt32Opt/bin So i am not sure what is the cause of the problem Thank you very much !!! Last edited by wyldckat; August 27, 2019 at 18:52. Reason: Added [CODE][/CODE] markers |
August 27, 2019, 19:01 |
Bruno Santos
Rep Power: 128 |
Quick answers:
August 27, 2019, 21:25 |
zhenhai zhang
Rep Power: 7 |
Hello Bruno
Thank you for your reply ! When i tried your suggestion, i found out that my university's cluster does not have 'openmpi-x86_64' available, so i loaded a one of existing openmpi which is 'openmpi/1.10.7-mlx' then i tried to compile the openFOAM with ./Allwmake and i get the following warning: Code:
/home/zzha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: undefined reference to `MPI_Finalize' /home/zzha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: undefined reference to `ompi_mpi_op_sum' /home/zzha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: undefined reference to `MPI_Buffer_attach' /home/zzha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so: undefined reference to `MPI_Group_free' collect2: error: ld returned 1 exit status make[3]: *** [/home/zzha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/platforms/linux64GccDPInt32Opt/bin/rhoPorousSimpleFoam] Error 1 make[2]: *** [rhoPorousSimpleFoam] Error 2 make[1]: *** [rhoSimpleFoam] Error 2 make: *** [compressible] Error 2 By the looks of error message, i am not sure if it is to do with the openmpi that i did not use the right one or something else i am not doing correctly. So the Openmpis that is available in the cluster is as follows: Code:
openmpi/1.10.3-gcc4-mlx openmpi/1.10.3-gcc4-mlx-cuda75 openmpi/1.10.3-gcc4-mlx-verbs openmpi/1.10.3-gcc4-mlx-verbs-cuda75 openmpi/1.10.3-gcc5 openmpi/1.10.3-gcc5-mlx openmpi/1.10.7-1.mlx openmpi/1.10.7-intel openmpi/1.10.7-mlx(default) openmpi/3.1.4-mlx opennmt-py/0.7.0 And i am so sorry if i am asking very obvious questions, but i have zero experience in doing jobs in cluster previously. Thank your very much for your patience! |
August 28, 2019, 19:21 |
Bruno Santos
Rep Power: 128 |
Quick answer: The commands you should execute are as follows:
module load openmpi/1.10.7-mlx source $HOME/OpenFOAM/OpenFOAM-v1906/etc/bashrc Then check what error messages you get. If you only get the error about "no completion added", then Open-MPI should be ready to be used with OpenFOAM. If so far so good, then run: Code:
foam ./Allwmake -j 4 -log=log.make However, if sourcing OpenFOAM's "etc/bashrc" file gave the error about mpicc or some other error, then run: Code:
echo $MPI_ARCH_PATH ls -l $MPI_ARCH_PATH ls -l $MPI_ARCH_PATH/include |
August 29, 2019, 04:28 |
zhenhai zhang
Rep Power: 7 |
Hi Bruno
Thanks for replying! When i load the openmpi and source the bashrc, there was nothing happening in the command window so i waited for a hour or two and found out there was still nothing. and i can not type any command either except ctrl+C to terminate the process. Code:
[zzha518@monarch-login1 ~]$ source /home/zzha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/etc/bashrc I am not sure if it is suppose to take that long to source the bashrc or anything has gone wrong again? But the following is the what i get when i call the $MPI_ARCH_PATH Code:
[zzha518@monarch-login1 ~]$ echo $MPI_ARCH_PATH /usr/local/openmpi/1.10.7-mlx Code:
[zzha518@monarch-login1 ~]$ ls -l $MPI_ARCH_PATH total 13 drwxr-xr-x 2 chines monashuniversity 70 Mar 14 2018 bin drwxr-xr-x 2 chines monashuniversity 7 Mar 14 2018 etc drwxr-xr-x 6 chines monashuniversity 25 Mar 14 2018 include drwxr-xr-x 4 chines monashuniversity 83 Dec 3 2018 lib drwxr-xr-x 4 chines monashuniversity 84 Nov 30 2018 lib2 drwxr-xr-x 5 chines monashuniversity 5 Mar 14 2018 share Code:
[zzha518@monarch-login1 ~]$ ls -l $MPI_ARCH_PATH/include total 97 -rw-r--r-- 1 chines monashuniversity 255 Mar 14 2018 mpi-ext.h -rw-r--r-- 1 chines monashuniversity 2712 Mar 14 2018 mpif-config.h -rw-r--r-- 1 chines monashuniversity 10974 Mar 14 2018 mpif-constants.h -rw-r--r-- 1 chines monashuniversity 1954 Mar 14 2018 mpif-externals.h -rw-r--r-- 1 chines monashuniversity 188 Mar 14 2018 mpif-ext.h -rw-r--r-- 1 chines monashuniversity 2715 Mar 14 2018 mpif.h -rw-r--r-- 1 chines monashuniversity 7740 Mar 14 2018 mpif-handles.h -rw-r--r-- 1 chines monashuniversity 2122 Mar 14 2018 mpif-io-constants.h -rw-r--r-- 1 chines monashuniversity 1207 Mar 14 2018 mpif-io-handles.h -rw-r--r-- 1 chines monashuniversity 2955 Mar 14 2018 mpif-sentinels.h -rw-r--r-- 1 chines monashuniversity 1152 Mar 14 2018 mpif-sizeof.h -rw-r--r-- 1 chines monashuniversity 166835 Mar 14 2018 mpi.h -rw-r--r-- 1 chines monashuniversity 16055 Mar 14 2018 mpi_portable_platform.h drwxr-xr-x 2 chines monashuniversity 4 Mar 14 2018 mpp drwxr-xr-x 3 chines monashuniversity 3 Mar 14 2018 openmpi drwxr-xr-x 3 chines monashuniversity 4 Mar 14 2018 openshmem -rw-r--r-- 1 chines monashuniversity 19913 Mar 14 2018 pshmem.h -rw-r--r-- 1 chines monashuniversity 13158 Mar 14 2018 pshmemx.h -rw-r--r-- 1 chines monashuniversity 1384 Mar 14 2018 shmem-compat.h -rw-r--r-- 1 chines monashuniversity 1692 Mar 14 2018 shmem.fh -rw-r--r-- 1 chines monashuniversity 21648 Mar 14 2018 shmem.h -rw-r--r-- 1 chines monashuniversity 12515 Mar 14 2018 shmemx.h drwxr-xr-x 3 chines monashuniversity 23 Mar 14 2018 vampirtrace Regards |
September 1, 2019, 20:41 |
zhenhai zhang
Rep Power: 7 |
Hi Bruno
It seems that it was the server to have a technical issue from my last post to not respond. And this is what i get when i run the process again when the cluster is normal again. So when i try to load the openmpi-1.10.7 i give the following message: Code:
[zzha518@monarch-login2 ~]$ module load openmpi/1.10.7-1.mlx DO NOT USE THIS MODULE> IT IS FOR TESTING ONLY [zzha518@monarch-login2 ~]$ source /home/zzha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/etc/bashrc bash: mpicc: command not found... bash: mpicc: command not found... So i changed to another openmpi (openmpi/1.10.3-gcc5). then i source the bashrc and get the following: Code:
[zzha518@monarch-login2 ~]$ module load openmpi/1.10.3-gcc5 [zzha518@monarch-login2 ~]$ source /home/zzha518/ny81/zzha518/OpenFOAM/OpenFOAM-v1906/etc/bashrc mpicc: error while loading shared libraries: libslurm.so.30: cannot open shared object file: No such file or directory mpicc: error while loading shared libraries: libslurm.so.30: cannot open shared object file: No such file or directory mpicc: error while loading shared libraries: libslurm.so.30: cannot open shared object file: No such file or directory Any suggesting on where should i proceed next? Thank you very much!! Regards |
cluster setup, openfoam |
[Other] Basic questions about OpenFOAM cluster running and installing | Fauster | OpenFOAM Installation | 0 | May 25, 2018 16:00 |
[OpenFOAM.org] OpenFOAM Cluster Setup for Beginners | Ruli | OpenFOAM Installation | 7 | July 22, 2016 05:14 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 16:15 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 07:55 |
unable to install openfoam 1.7 using apt-get | maazhmd | OpenFOAM Installation | 7 | July 24, 2011 12:18 |
