[OpenFOAM.com] controlDict not found after windows installation |
August 5, 2019, 19:42 |
Daniel
Rep Power: 8 |
I'm trying to install OpenFoam on my Windows 10 computer.
I followed the installation instructions given at the OF webpage: https://www.openfoam.com/download/tx...adme_v1906.txt The installation proceeded more or less automatic. Once intallation was complete I clicked on the OF_Create_Env shortcut in my desktop, followed by OpenFOAM_Start shorcut. That opened up a powershell window with the following: Code:
Starting "default"... Machine "default" is already running. of_1906 [ofuser@default ~]$ Code:
Create time --> FOAM FATAL ERROR: cannot find file "/home/ofuser/system/controlDict" How con I fix this error? Where do I find such file? Thanks |
August 5, 2019, 20:06 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Start reading and following the tutorials guide from here: https://www.openfoam.com/documentati...troduction.php
August 7, 2019, 13:22 |
Daniel
Rep Power: 8 |
wyldckat, I read the first few pages but it does not seem to be helpful to my issue here.
The only windows related note is: When using a shared directory, e.g. between Windows and Docker, users may prefer to use a Windows-based text editor. However, care should be taken not to change the encoding of the text files to ensure that they remain readable by OpenFOAM. Good choices may be atom and PSPad — both are free and automatically keep the correct encoding. Which I really dont understand. |
August 25, 2019, 09:28 |
#4 | |
Bruno Santos
Rep Power: 128 |
Quick answer(s)/question(s):
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
