[OpenFOAM.org] I can't see openfoam directory in home |
July 5, 2019, 12:28 |
Piotr Doroszko
Hi, I'm first time Ubuntu user and I have a question which probably will sound pretty stupid.
I've dual booted Ubuntu 18.04.2 LTS on my laptop alongside Windows 10, then I've followed instructions from: https://openfoam.org/download/6-ubuntu/ It seems everything went well. I've added ". /opt/openfoam6/etc/bashrc" at the end of a text file and saved. I've typed: Code:
source /opt/openfoam6/etc/bashrc The problem boils down to the fact that I can't find an application which I think I've installed correctly and my incompetence with the new OS makes it difficult to perform basic tasks. |
July 5, 2019, 13:48 |
Piotr Doroszko
Ok, I've figured it out. Sorry for bothering you and littering the forum with unnecessary threads.
July 9, 2019, 18:33 |
#3 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Piotrekdoro,
Anyway, if in the future you end up finding a solution to a question you made, please write the answer you finally found For others reading this thread, the idea here is that when OpenFOAM is installed in "/opt", this means that all installed files for it are placed there and not in the "/home" folder. However, if you follow the User Guides, they will tell you a sequence of commands that will indeed create a new folder in your home folder, so that you can place a copy of the tutorial(s) from "/opt" onto your home folder. That way you work on a copy, instead of working on the original files. As for knowing if the installation is working or not, in the instructions page that you follow, you should be able to find instructions on what to do next after installation. In the link provided, the last section at https://openfoam.org/download/6-ubuntu/ - does give the instructions needed. Although make sure you didn't skip anything, because it's very easy to accidentally scroll by critical steps. Best regards, Bruno
August 20, 2020, 01:34 |
#4 | |
Srijit Sen
Rep Power: 8 |
First step: cd ~ Second step: mkdir -p $FOAM_RUN You will find the required directory |
[OpenFOAM.org] OpenFoam deug mode | FMurad | OpenFOAM Installation | 4 | August 25, 2019 08:04 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
