[foam-extend.org] Installing Foam Extend 4.0 on Linux Mint
Old   May 10, 2019, 12:56
Default Installing Foam Extend 4.0 on Linux Mint
Andy Southern
andysuth is on a distinguished road
I've tried several times to install Foam Extend 4.0 on a fresh install of Linux Mint, but it fails with some odd behaviour.
Bashrc has two aliases in it "FE40" alias for the Foam Extend and "OF6" alias, but simple foam reports version 4.0 is installed before either alias is triggered, OF6 alias reports OF6 is installed, and FE40 alias reports an error.
Has anyone successfully installed foam extend 4.0 on Linux Mint?
Thanks
andysuth is offline   Reply With Quote
Old   May 11, 2019, 09:37
Retired Super Moderator
Bruno Santos
Quick questions:
  1. Which specific Linux Mint version are you using?
  2. Please provide the actual custom lines that you defined in your personal file "~/.bashrc", because it feels like there is something that you might be noticing... if you're not sure, run this command and provide its output in your next post:
    cat ~/.bashrc
NO Moving Probes for Moving Mesh in Foam Extend 4.0 alia OpenFOAM Running, Solving & CFD 6 June 25, 2018 10:24
Possible Memory problem with foam extend 4.0 HenrikJohansson OpenFOAM Running, Solving & CFD 1 April 19, 2018 09:07
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 23:50
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
