[foam-extend.org] Problems compiling foam-extend-4.0 + fsiFoam on Ubuntu+WSL |
#41 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answers @singh500:
#42 |
Kushagra
Rep Power: 7 ![]() |
Yes, I had OpenFOAM v1906 as well, open at the same time in a different window. I will follow the link you shared and see how it helps.
The instructions I am following is same as what you shared in this thread. I have attached for you reference. Thank you very much. I am using Ubuntu 16.04 in WSL. Last edited by singh500; August 27, 2019 at 10:50. Reason: Forgot to mention Ubuntu version |
#43 |
Kushagra
Hi Bruno,
I used the instructions indicated by now and my problem is fixed now. I have run cavity tutorial which works fine and trying out FSI now. Thanks. |
#44 |
alberto
Rep Power: 10 ![]() |
I have a problem, I hope some one can help me. I am trying to do a FSI simulation. I create a Mesh for the fluid and use the utility extrudeMesh to get the solid Mesh. When I run my case in series I dont have problem. But when I try to run my case in parallel, and use the decomposePar utility for the solid region I get this error, and when I descompose the fluid region doesnt have problem. Code:
Decomposing mesh solid Create time Time = 0 Create mesh for region solid Calculating distribution of cells Selecting decompositionMethod simple Finished decomposition in 0.02 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Calculating processor boundary addressing Distributing points to processors Constructing processor meshes Violación de segmento (`core' generado) |
#45 |
Ali Shayegh
I don't think it is that hard to update foam-extend 4.0 repository so that, in Third-party compilation section, we have the latest version of paraview to be compiled rather than paraview 4.4.0. Any idea?
#46 | |
Daniel
Rep Power: 21 ![]() |
I think it uses Paraview 5.5.2 ![]() If you don't want to update, then it is not that hard: 1- Update the corresponding scripts to download, compile and run the latest paraview. 2- Update the PVReader of foam-extend-4.0 to work with the latest paraview. The easiest way would be to look into the nextRelease branch of foam-extend-4.0 project for the needed changes! |
#47 | |
Anas Muhamad Pauzi
Rep Power: 6 ![]() |
I'm having the same output as yours. I don't think to have any problem in the installation of my foam-extend, since I've ran most built in tutorials smoothly. Can anyone help? My output is exactly as below. Running paraFoam on the 3dTube case would show no flow or deflection Thank you Quote:
#48 |
kang seung-hwan
@JBrake Hi
Did you solve the problem? I am having same problem. I am stuck in installation of extend 4.0 on Ubuntu 16.04 in Windows 10. It is frozen at stage 3 or stage 1. |
#49 |
Jiayu Sun
#50 |
Merlin Williams
Rep Power: 4 ![]() |
I have read multiple forums and had a lot of trouble trying to get foam-extend 4.0 to install correctly on my WSL Ubuntu 20.04. After getting the souce code from this website: http://openfoamwiki.net/index.php/In...oam-extend-4.0 I then run these commands: sudo sh -c 'echo deb http://gb.archive.ubuntu.com/ubuntu/ bionic universe > /etc/apt/sources.list.d/bionic_legacy.list' sudo apt-get update Then when I run this command: sudo apt-get install git-core build-essential binutils-dev cmake flex bear \ zlib1g-dev libncurses5-dev libreadline-dev \ libxt-dev rpm mercurial graphviz python python-dev python3 python3-dev gcc-5 g++-5 \ gnuplot gnuplot-qt gnuplot-data I get the error: E: Unable to locate package qt4-dev-tools E: Package 'libqt4-dev' has no installation candidate When i finish the installation process and finish compiling it, if i try run a tutorial, whenever I input the command blockMesh, i get the error: Command 'blockMesh' not found, but can be installed with: sudo apt install openfoam To my knowledge foam-extend 4.0 installed similar commands to main openfoam distributions. Please can somebody advise me how to install foam-extend 4.0 successfully. best regards Merlin |
foam-extend 4.0, fsifoam |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] cgnsToFoam problems with "QUAD_4" cells | lentschi | OpenFOAM Meshing & Mesh Conversion | 1 | March 9, 2011 04:49 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
