[OpenFOAM.org] I have trouble installing openfoam 5.0 on ubuntu 16.04 |
Rep Power: 9 ![]() |
Hi ,
I want to install of5 on Ubuntu 16.04, I tried installing description in"https://openfoam.org/download/5-0-ubuntu/" but it not work, and last time i got this massage : Code:
Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: openfoam5 : Depends: binutils-dev but it is not going to be installed Depends: libxt-dev but it is not going to be installed E: Unable to correct problems, you have held broken packages. |
Retired Super Moderator
Bruno Santos
Rep Power: 128 ![]() ![]() ![]() ![]() ![]() ![]() |
Quick answer: I know I've seen this problem before, but I can't remember exactly why this was happening back then...
So my request is as follows:
#3 | |
Thank you for replay, please accept my apologies for delayed response,
The out put for first command is: Fetched 384 B in 1min 1s (6 B/s) Reading package lists... Done W: The repository 'http://dl.openfoam.org/ubuntu xenial Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. W: The repository 'http://ubuntu.sepidvas.com/ubuntu xenial Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. W: The repository 'http://ubuntu.sepidvas.com/ubuntu xenial-updates Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. W: The repository 'http://ubuntu.sepidvas.com/ubuntu xenial-backports Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. W: The repository 'http://ubuntu.sepidvas.com/ubuntu xenial-security Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. Quote:
W: The repository 'http://dl.openfoam.org/ubuntu xenial Release' does not have a Release file. N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use. N: See apt-secure(8) manpage for repository creation and user configuration details. Last edited by wyldckat; December 25, 2018 at 17:17. Reason: merged posts a few minutes apart |
Bruno Santos
Quick answer: It looks like there is a problem with the machine with Ubuntu is having difficulties accessing the Internet.
Perhaps you are using a proxy server in Ubuntu? Because if you are, then it needs additional configuration: https://askubuntu.com/questions/2572...-proxy-for-apt If you have Ubuntu installed inside a virtual machine or Windows 10 WSL, then you will need to configure it to be able to access the internet from your real machine... but without knowing more details, it's hard to provide more guidance. |
#5 | |
I installed ubuntu on a virtual machine, but every time I want to install openfoam, first I check internet connection and sure it works properly. please help me, I'm really confused why this problem occurs Last time I tried to install, the update command goes well, but install command ended with an error like this: E: Unable to locate package OpenFOAM5 |
Bruno Santos
Quick answer: Please follow these steps:
openfoam 5.0, ubuntu 16.04 |
[FSI] Having trouble installing FSI_4.0 on foam-extend 4.1 and Ubuntu 16.04 | Aliiiii | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 11 | May 26, 2022 05:00 |
OpenFOAM 5.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 11 | June 5, 2018 23:48 |
[OpenFOAM.com] v3.0+ Problems installing on Ubuntu 16.04 | Evander | OpenFOAM Installation | 3 | March 26, 2017 14:47 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
