[OpenFOAM.org] version 2.1.1: problem in making Paraview on LInux 14.04
Old   November 26, 2018, 14:34
Default version 2.1.1: problem in making Paraview on LInux 14.04
Alireza
alireza.sh is on a distinguished road
Dear users
I used the:
./makeParaView
to install ThirdParty-2.1.1 on UBUNTU14.04
I receive the error in the middle of installation:
[ 80%] Built target vtkSMExtractDocumentation
[ 81%] Built target QtTesting
[ 81%] Built target TestingDemo
[ 83%] Built target pqWidgets
[ 83%] Building CXX object Qt/Core/CMakeFiles/pqCore.dir/pqAnimationScene.cxx.o
In file included from /home/alireza/OpenFOAM/ThirdParty-2.1.1/ParaView-3.12.0/Qt/Core/pqAnimationScene.cxx:57:0:
/home/alireza/OpenFOAM/ThirdParty-2.1.1/ParaView-3.12.0/Qt/Core/pqServerManagerSelectionModel.h:75:30:  error: calls to overloaded operators cannot appear in a  constant-expression
make[2]: *** [Qt/Core/CMakeFiles/pqCore.dir/pqAnimationScene.cxx.o] Error 1
make[1]: *** [Qt/Core/CMakeFiles/pqCore.dir/all] Error 2
make: *** [all] Error 2
    Installation complete for paraview-3.12.0
    Set environment variables:
        export ParaView_DIR=/home/alireza/OpenFOAM/ThirdParty-2.1.1/platforms/linux64Gcc47/paraview-3.12.0
        export PATH=$ParaView_DIR/bin:$PATH
        export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.12
How can I solve this problem??
Thanks alot
alireza.sh is offline   Reply With Quote
Old   December 4, 2018, 18:09
Retired Super Moderator
Bruno Santos
Quick answer: Sorry for the late reply and got not getting back to you sooner on the other thread about installing on Ubuntu 18.04... I haven't had time to look into this properly
As for the problem you've reported here, I believe that the problem is that the following commands need to be executed:
cd $WM_THIRD_PARTY_DIR
sed -i -e 's/\(export CXX.*$\)/\1\n[ -n "$WM_CC" ] \&\& export CC="$WM_CC"/' makeParaView
Then you can try again to build ParaView, following the instructions that you've used...
Which reminds me: Which instructions are you following here?
[PyFoam] Problems with installing PyFoam Christoph_84 OpenFOAM Community Contributions 34 October 26, 2021 12:25
[Other] Openfoam for windows 16.02 [CFD support] -problem with paraview ditmeyer OpenFOAM Installation 3 May 15, 2017 13:04
Problems building Paraview 3.12 on Gentoo Linux pajot OpenFOAM Installation 11 April 11, 2013 09:09
LINUX newbie with paraView installation problem kenya0514 OpenFOAM Installation 4 January 16, 2013 18:51
[OpenFOAM] Problem with paraFoam on a linux-64 bit bunni ParaView 4 April 14, 2010 21:55
