[OpenFOAM.com] Install OF1806 with system thirdparty packages |
September 29, 2018, 16:13 |
Rep Power: 21 |
I have freshly installed Kubuntu 18.04 and want to install several OF versions on it. Hence i installed all the dependencies using apt-get to not use unnecessary double installs under ThirdParty for every version. I changed the following files in config.sh: FFTW CGAL metis scotch with the following small changes:
fftw_version=fftw-system boost_version=boost-system cgal_version=cgal-system METIS_VERSION=metis-system SCOTCH_VERSION=scotch-system Code:
WARNING: skipping pt-scotch - no mpi or <scotch.h> not found Using fftw-system (skip ThirdParty build of FFTW) ==> skip ccmio (no header) ==> skip optional libccm adapter ==> skip scotch (missing library) ==> skip metis (no header) ==> skip randomProcesses library (no FFTW) ==> skip SloanRenumber (no boost) ==> skip zoltanRenumber (no library) WARNING: skipped - needs a VTK or a ParaView installation ==> skip dnsFoam solver (no FFTW) ==> skip optional ccm conversion components (no libccm.so) ==> skip build of ParaView plugins ==> skip noise utility (no FFTW) ==> skip boxTurb utility (no FFTW) WARNING: skip ParaView Catalyst (missing or incorrrect ParaView) skip wmake target for modules doxygen directory |
October 5, 2018, 05:49 |
#2 | |
Mark Olesen
Rep Power: 40 |
Could open an issue on gitlab (https://develop.openfoam.com) and post some settings there? This could be a more direct way to solve things. It could be that the packages install in various scattered locations without a common prefix, below which it can find the corresponding include and lib dirs. Could also be something else. /mark |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Need ideas-fuel discharge system | Jan | FLUENT | 1 | October 10, 2006 23:05 |
Need ideas-fuel discharge system | Jan | CFX | 1 | October 9, 2006 08:16 |
Need ideas-fuel discharge system | Jan | Main CFD Forum | 0 | October 9, 2006 04:27 |
help install fluent in RedHat system | arwang | FLUENT | 8 | July 13, 2004 10:07 |
