[OpenFOAM.org] Qt and Gcc errors while installing OF-4.0 on CentOS 6.10 HPC
Old   September 20, 2018, 09:54
Default Qt and Gcc errors while installing OF-4.0 on CentOS 6.10 HPC
So Anon
redbullah is on a distinguished road
Hello all,
I am trying to install OF-4.0 on the HPC which runs CentOS 6.10 by following the instructions given here:
https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL
(although it is given for CentOS 6.8)
1. I get the following error in makeGcc log
xgcc: error trying to exec 'cc1': execvp: No such file or directory
2. I get the following errors in the last lines of makeQt log
Project ERROR: Package gstreamer-app-0.10 not found
make[1]: *** [WebCore/Makefile.WebKit] Error 2
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [WebKit/qt/Makefile.WebKit.QtWebKit] Error 2
make[1]: Leaving directory `/cfd/honel/OpenFOAM/ThirdParty-4.0/build/linux64Gcc/qt-everywhere-opensource-src-4.8.6/src/3rdparty/webkit/Source'
make: *** [sub-webkit-make_default-ordered] Error 2
real	7m37.089s
user	44m56.011s
sys	2m55.868s
Error building: Qt-4.8.6
I guess this also affects ParaView installation, since I get this log for makePV:
Python information:
    executable     : /usr/bin/python
    version        : 2.6
    include path   : /usr/include/python2.6
    library        : /usr/lib64/libpython2.6.so.1.0
qmake not found under specified QMAKE_PATH
    QMAKE_PATH=/cfd/honel/OpenFOAM/ThirdParty-4.0/platforms/linux64Gcc/qt-4.8.6/bin/qmake
leaving unspecified
Is it because of the 6.10 version of CentOS? How can I solve this?
redbullah is offline   Reply With Quote
Old   September 20, 2018, 17:45
Default Missing Compilers
Peter Brady
pbrady2013 is on a distinguished road
cc1 and qmake are compilers being part of the GCC and QT projects respecitvely. The errors suggest to me one of two things:
  1. the compilers are installed but not on the search path
  2. the compilers are not installed
Following on from there. I try to run C7.x but I've got a few boxes that run C6.x. On the C6 boxes I have had enough trouble with the native compilers that I roll my own GCC and mpi to compile. On an HPC node I usually wouldn't bother to compile Paraview as I have a visualisation workstation and cluster to do that processing.
So, suggestions are to check the paths to ensure the compilers are installed and available, otherwise make sure to install the required compilers.
Hope that helps,
-pete
pbrady2013 is offline   Reply With Quote
