[foam-extend.org] foam-extend 3.2 Paraview installation problem on Ubuntu 18.04 |
August 29, 2018, 13:10 |
#1 | ||
Emre
Rep Power: 11 |
I tried to install foam-extend 3.2 on Ubuntu 18.04 LTS by following the instructions in https://openfoamwiki.net/index.php/I...oam-extend-3.2 and https://openfoamwiki.net/index.php/I...end-3.2/Ubuntu. I thought I succeeded. Because I saw time steps in case folder. Then I typed paraFoam. It failed. Lastly I realised ParaView is missing: Quote:
Here is the file that I created after I went to ThirdParty folder, then typed ./AllClean and ./AllMake: 3RDPARTYLOG.tar.gz Regard, Emre Last edited by ordinary; August 29, 2018 at 15:00. |
August 29, 2018, 15:56 |
#2 | |
Emre
Rep Power: 11 |
Hello I also have same problem with Paraview. I did all the things have been said (tried both export QT_BIN_DIR=/home/emre/usr/bin/ and export QT_BIN_DIR=/home/emre/usr/bin/qmake in prefs.sh file). There is no feedback for which paraview command. I can't install Paraview. I tried to ./AllMake.stage4 and ./AllMake but it gives me same weird message:
Any help is appreciated. Best regards, Emre [Moderator note: Moved this post from here: paraview not runing? (foam extended 3.2 and ubuntu 15.04)] Last edited by wyldckat; September 1, 2018 at 14:51. Reason: see "Moderator note:" |
August 29, 2018, 16:57 |
Emre
Rep Power: 11 |
Hello again,
Somehow I managed code to run: Code:
emre@toshiba:~/foam/foam-extend-3.2/ThirdParty$ ./AllMake.stage4 This system rpm command: rpm --force-debian ======================================== Starting ThirdParty AllMake: Stage4 ======================================== Using system installed QT Building ParaView 4.3.1 Package name : ParaView-4.3.1 Package URL : http://downloads.sourceforge.net/pro...-source.tar.gz RPM spec file name: ParaView-4.3.1.spec Additional flags : --define=_qmakePath $QT_BIN_DIR/qmake Updating the ThirdParty environment variables before building package ParaView-4.3.1 RPM file name : /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.3.1-linux64GccDPOpt.x86_64.rpm Download ParaView-v4.3.1-source.tar.gz from : http://downloads.sourceforge.net/pro...-source.tar.gz --2018-08-29 22:40:27-- http://downloads.sourceforge.net/pro...-source.tar.gz Resolving downloads.sourceforge.net (downloads.sourceforge.net)... 216.105.38.13 Connecting to downloads.sourceforge.net (downloads.sourceforge.net)|216.105.38.13|:80... connected. HTTP request sent, awaiting response... 302 Found Location: https://datapacket.dl.sourceforge.ne...-source.tar.gz [following] --2018-08-29 22:40:27-- https://datapacket.dl.sourceforge.ne...-source.tar.gz Resolving datapacket.dl.sourceforge.net (datapacket.dl.sourceforge.net)... 185.152.64.70 Connecting to datapacket.dl.sourceforge.net (datapacket.dl.sourceforge.net)|185.152.64.70|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 50842525 (48M) [application/x-gzip] Saving to: ‘ParaView-v4.3.1-source.tar.gz’ ParaView-v4.3.1-sou 100%[===================>] 48,49M 928KB/s in 52s 2018-08-29 22:41:21 (947 KB/s) - ‘ParaView-v4.3.1-source.tar.gz’ saved [50842525/50842525] Making package ParaView-4.3.1 using RPM. Building package ParaView-4.3.1 using SPEC file : ParaView-4.3.1.spec. Optional args: --define=_qmakePath $QT_BIN_DIR/qmake Executing(%prep): /bin/sh -e /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/tmp/rpm-tmp.1JbbLd + umask 022 + cd /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD + cd /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD + rm -rf ParaView-v4.3.1-source + /bin/gzip -dc /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/SOURCES/ParaView-v4.3.1-source.tar.gz + /bin/tar -xof - + STATUS=0 + [ 0 -ne 0 ] + cd ParaView-v4.3.1-source + /bin/chmod -Rf a+rX,u+w,g-w,o-w . + exit 0 Executing(%build): /bin/sh -e /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/tmp/rpm-tmp.1Z199d + umask 022 + cd /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD + cd ParaView-v4.3.1-source + [ -n gcc ] + export CC=gcc + [ -n g++ ] + export CXX=g++ + [ -n -m64 -fPIC ] + export CFLAGS=-m64 -fPIC + [ -n -m64 -fPIC ] + export CXXFLAGS=-m64 -fPIC + [ -n -m64 ] + export LDFLAGS=-m64 + set +x Compilation options: _withVerbose : false _withMesa : false _withMPI : false _withPython : false _withQt : true _qmakePath : /usr/bin//qmake _mesaIncludePath : Undefined _mesaLibPath : Undefined _pythonLibPath : Undefined + addCMakeVariable BUILD_SHARED_LIBS:BOOL=ON + [ -n BUILD_SHARED_LIBS:BOOL=ON ] + CMAKE_VARIABLES= -DBUILD_SHARED_LIBS:BOOL=ON + shift + [ -n ] + addCMakeVariable CMAKE_BUILD_TYPE:STRING=Release + [ -n CMAKE_BUILD_TYPE:STRING=Release ] + CMAKE_VARIABLES= -DBUILD_SHARED_LIBS:BOOL=ON -DCMAKE_BUILD_TYPE:STRING=Release + shift + [ -n ] + addCMakeVariable BUILD_TESTING:BOOL=OFF + [ -n BUILD_TESTING:BOOL=OFF ] + CMAKE_VARIABLES= -DBUILD_SHARED_LIBS:BOOL=ON -DCMAKE_BUILD_TYPE:STRING=Release -DBUILD_TESTING:BOOL=OFF + shift + [ -n ] + addCMakeVariable PARAVIEW_ENABLE_PYTHON:BOOL=ON + [ -n PARAVIEW_ENABLE_PYTHON:BOOL=ON ] + CMAKE_VARIABLES= -DBUILD_SHARED_LIBS:BOOL=ON -DCMAKE_BUILD_TYPE:STRING=Release -DBUILD_TESTING:BOOL=OFF -DPARAVIEW_ENABLE_PYTHON:BOOL=ON + shift + [ -n ] + addCMakeVariable PARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON + [ -n PARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON ] + CMAKE_VARIABLES= -DBUILD_SHARED_LIBS:BOOL=ON -DCMAKE_BUILD_TYPE:STRING=Release -DBUILD_TESTING:BOOL=OFF -DPARAVIEW_ENABLE_PYTHON:BOOL=ON -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON + shift + [ -n ] + addCMakeVariable QT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin//qmake + [ -n QT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin//qmake ] + CMAKE_VARIABLES= -DBUILD_SHARED_LIBS:BOOL=ON -DCMAKE_BUILD_TYPE:STRING=Release -DBUILD_TESTING:BOOL=OFF -DPARAVIEW_ENABLE_PYTHON:BOOL=ON -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DQT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin//qmake + shift + [ -n ] + echo CMAKE_VARIABLES: -DBUILD_SHARED_LIBS:BOOL=ON -DCMAKE_BUILD_TYPE:STRING=Release -DBUILD_TESTING:BOOL=OFF -DPARAVIEW_ENABLE_PYTHON:BOOL=ON -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DQT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin//qmake CMAKE_VARIABLES: -DBUILD_SHARED_LIBS:BOOL=ON -DCMAKE_BUILD_TYPE:STRING=Release -DBUILD_TESTING:BOOL=OFF -DPARAVIEW_ENABLE_PYTHON:BOOL=ON -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DQT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin//qmake + mkdir -p ./buildObj + cd ./buildObj + cmake -DCMAKE_INSTALL_PREFIX:PATH=/home/emre/foam/foam-extend-3.2/ThirdParty/packages/ParaView-4.3.1/platforms/linux64GccDPOpt -DBUILD_SHARED_LIBS:BOOL=ON -DCMAKE_BUILD_TYPE:STRING=Release -DBUILD_TESTING:BOOL=OFF -DPARAVIEW_ENABLE_PYTHON:BOOL=ON -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DQT_QMAKE_EXECUTABLE:FILEPATH=/usr/bin//qmake .. -- The C compiler identification is GNU 7.3.0 -- The CXX compiler identification is GNU 7.3.0 -- Check for working C compiler: /usr/bin/gcc -- Check for working C compiler: /usr/bin/gcc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Detecting C compile features -- Detecting C compile features - done -- Check for working CXX compiler: /usr/bin/g++ -- Check for working CXX compiler: /usr/bin/g++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Detecting CXX compile features -- Detecting CXX compile features - done -- Found Git: /usr/bin/git (found version "2.17.1") -- Could not use git to determine source version, using version 4.3.1 -- Looking for a Fortran compiler -- Looking for a Fortran compiler - /usr/bin/f95 -- The Fortran compiler identification is GNU -- Check for working Fortran compiler: /usr/bin/f95 -- Check for working Fortran compiler: /usr/bin/f95 -- works -- Detecting Fortran compiler ABI info -- Detecting Fortran compiler ABI info - done -- Checking whether /usr/bin/f95 supports Fortran 90 -- Checking whether /usr/bin/f95 supports Fortran 90 -- yes -- Looking for Q_WS_X11 -- Looking for Q_WS_X11 - found -- Looking for Q_WS_WIN -- Looking for Q_WS_WIN - not found -- Looking for Q_WS_QWS -- Looking for Q_WS_QWS - not found -- Looking for Q_WS_MAC -- Looking for Q_WS_MAC - not found -- Found Qt4: /usr/bin/qmake (found suitable version "4.8.7", minimum required is "4.7.0") -- Performing Test HAVE_GCC_ERROR_RETURN_TYPE -- Performing Test HAVE_GCC_ERROR_RETURN_TYPE - Success -- Performing Test HAVE_GCC_VISIBILITY -- Performing Test HAVE_GCC_VISIBILITY - Success CMake Error at VTK/CMake/vtkCompilerExtras.cmake:42 (if): if given arguments: "gcc: error: ARGS: No such file or directory gcc (Ubuntu 7.3.0-16ubuntu3) 7.3.0 Copyright (C) 2017 Free Software Foundation, Inc. This is free software" " see the source for copying conditions. There is NO warranty" " not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. " "VERSION_GREATER" "4.2.0" "AND" "BUILD_SHARED_LIBS" "AND" "HAVE_GCC_VISIBILITY" "AND" "VTK_USE_GCC_VISIBILITY" "AND" "NOT" "MINGW" "AND" "NOT" "CYGWIN" Unknown arguments specified Call Stack (most recent call first): VTK/CMakeLists.txt:239 (include) -- Configuring incomplete, errors occurred! See also "/home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeOutput.log". See also "/home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeError.log". error: Bad exit status from /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/tmp/rpm-tmp.1Z199d (%build) RPM build errors: Bad exit status from /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/tmp/rpm-tmp.1Z199d (%build) Installing package: ParaView-4.3.1 Uninstalling ParaView-4.3.1 using RPM: ParaView-4.3.1-linux64GccDPOpt.x86_64 Installing ParaView-4.3.1 using RPM file: /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.3.1-linux64GccDPOpt.x86_64.rpm error: open of /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/RPMS/x86_64/ParaView-4.3.1-linux64GccDPOpt.x86_64.rpm failed: No such file or directory Done installing package ======================================== Done ThirdParty AllMake: Stage4 ======================================== Code:
Determining if the Q_WS_WIN exist failed with the following output: Change Dir: /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp Run Build Command:"/usr/bin/make" "cmTryCompileExec3105029847/fast" /usr/bin/make -f CMakeFiles/cmTryCompileExec3105029847.dir/build.make CMakeFiles/cmTryCompileExec3105029847.dir/build make[1]: Entering directory '/home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp' /home/emre/foam/foam-extend-3.2/ThirdParty/packages/cmake-3.2.2/platforms/linux64GccDPOpt/bin/cmake -E cmake_progress_report /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CMakeFiles 1 Building CXX object CMakeFiles/cmTryCompileExec3105029847.dir/CheckSymbolExists.cxx.o /usr/bin/g++ -m64 -fPIC -I/usr/include/qt4 -o CMakeFiles/cmTryCompileExec3105029847.dir/CheckSymbolExists.cxx.o -c /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx: In function 'int main(int, char**)': /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:8:19: error: 'Q_WS_WIN' was not declared in this scope return ((int*)(&Q_WS_WIN))[argc]; ^~~~~~~~ /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:8:19: note: suggested alternative: 'Q_WS_X11' return ((int*)(&Q_WS_WIN))[argc]; ^~~~~~~~ Q_WS_X11 CMakeFiles/cmTryCompileExec3105029847.dir/build.make:57: recipe for target 'CMakeFiles/cmTryCompileExec3105029847.dir/CheckSymbolExists.cxx.o' failed make[1]: *** [CMakeFiles/cmTryCompileExec3105029847.dir/CheckSymbolExists.cxx.o] Error 1 make[1]: Leaving directory '/home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp' Makefile:117: recipe for target 'cmTryCompileExec3105029847/fast' failed make: *** [cmTryCompileExec3105029847/fast] Error 2 File /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx: /* */ #include <QtCore/qglobal.h> int main(int argc, char** argv) { (void)argv; #ifndef Q_WS_WIN return ((int*)(&Q_WS_WIN))[argc]; #else (void)argc; return 0; #endif } Determining if the Q_WS_QWS exist failed with the following output: Change Dir: /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp Run Build Command:"/usr/bin/make" "cmTryCompileExec3445289600/fast" /usr/bin/make -f CMakeFiles/cmTryCompileExec3445289600.dir/build.make CMakeFiles/cmTryCompileExec3445289600.dir/build make[1]: Entering directory '/home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp' /home/emre/foam/foam-extend-3.2/ThirdParty/packages/cmake-3.2.2/platforms/linux64GccDPOpt/bin/cmake -E cmake_progress_report /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CMakeFiles 1 Building CXX object CMakeFiles/cmTryCompileExec3445289600.dir/CheckSymbolExists.cxx.o /usr/bin/g++ -m64 -fPIC -I/usr/include/qt4 -o CMakeFiles/cmTryCompileExec3445289600.dir/CheckSymbolExists.cxx.o -c /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx: In function 'int main(int, char**)': /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:8:19: error: 'Q_WS_QWS' was not declared in this scope return ((int*)(&Q_WS_QWS))[argc]; ^~~~~~~~ /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:8:19: note: suggested alternative: 'Q_WS_X11' return ((int*)(&Q_WS_QWS))[argc]; ^~~~~~~~ Q_WS_X11 CMakeFiles/cmTryCompileExec3445289600.dir/build.make:57: recipe for target 'CMakeFiles/cmTryCompileExec3445289600.dir/CheckSymbolExists.cxx.o' failed make[1]: *** [CMakeFiles/cmTryCompileExec3445289600.dir/CheckSymbolExists.cxx.o] Error 1 make[1]: Leaving directory '/home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp' Makefile:117: recipe for target 'cmTryCompileExec3445289600/fast' failed make: *** [cmTryCompileExec3445289600/fast] Error 2 File /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx: /* */ #include <QtCore/qglobal.h> int main(int argc, char** argv) { (void)argv; #ifndef Q_WS_QWS return ((int*)(&Q_WS_QWS))[argc]; #else (void)argc; return 0; #endif } Determining if the Q_WS_MAC exist failed with the following output: Change Dir: /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp Run Build Command:"/usr/bin/make" "cmTryCompileExec2237777324/fast" /usr/bin/make -f CMakeFiles/cmTryCompileExec2237777324.dir/build.make CMakeFiles/cmTryCompileExec2237777324.dir/build make[1]: Entering directory '/home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp' /home/emre/foam/foam-extend-3.2/ThirdParty/packages/cmake-3.2.2/platforms/linux64GccDPOpt/bin/cmake -E cmake_progress_report /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CMakeFiles 1 Building CXX object CMakeFiles/cmTryCompileExec2237777324.dir/CheckSymbolExists.cxx.o /usr/bin/g++ -m64 -fPIC -I/usr/include/qt4 -o CMakeFiles/cmTryCompileExec2237777324.dir/CheckSymbolExists.cxx.o -c /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx: In function 'int main(int, char**)': /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:8:19: error: 'Q_WS_MAC' was not declared in this scope return ((int*)(&Q_WS_MAC))[argc]; ^~~~~~~~ /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:8:19: note: suggested alternative: 'Q_WS_X11' return ((int*)(&Q_WS_MAC))[argc]; ^~~~~~~~ Q_WS_X11 CMakeFiles/cmTryCompileExec2237777324.dir/build.make:57: recipe for target 'CMakeFiles/cmTryCompileExec2237777324.dir/CheckSymbolExists.cxx.o' failed make[1]: *** [CMakeFiles/cmTryCompileExec2237777324.dir/CheckSymbolExists.cxx.o] Error 1 make[1]: Leaving directory '/home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp' Makefile:117: recipe for target 'cmTryCompileExec2237777324/fast' failed make: *** [cmTryCompileExec2237777324/fast] Error 2 File /home/emre/foam/foam-extend-3.2/ThirdParty/rpmBuild/BUILD/ParaView-v4.3.1-source/buildObj/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx: /* */ #include <QtCore/qglobal.h> int main(int argc, char** argv) { (void)argv; #ifndef Q_WS_MAC return ((int*)(&Q_WS_MAC))[argc]; #else (void)argc; return 0; #endif } Last edited by wyldckat; September 1, 2018 at 14:52. Reason: [QUOTE]->[CODE] |
September 1, 2018, 23:01 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
For future readers: Start reading from post #7 at How to install foam-extend 4.0 in UBUNTU 18.04 - for a few possible solutions. I believe they should also work with foam-extend 3.2.
foam extend 3.2, openfoam installation, ubuntu 18.04 |
Sig Density Based Solver installation with FOAM Extend 3.2 | qjh888 | OpenFOAM Bugs | 0 | September 21, 2016 09:16 |
Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7 | Wley | OpenFOAM Installation | 2 | September 28, 2012 07:06 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
