[OpenFOAM.org] How to avoid using ThirdParty directory? |
August 6, 2018, 12:39 |
I'm using Fedora 28 and would like to compile OpenFOAM from source. While following the instructions on the OpenFOAM website, I realized that the software provided in the ThirdParty repository were provided as packages in the Fedora repositories.
I'd like to use these packages with OpenFOAM, but the compilation fails at Code:
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -DOMPI_SKIP_MPICXX -I/usr/include/openmpi-x86_64 -pthread -I.../OpenFOAM-6/src/Pstream/mpi/lnInclude -I.../ThirdParty-6/platforms/linux64GccDPInt32/scotch_6.0.3/include/openmpi-system -I.../ThirdParty-6/platforms/linux64GccDPInt32/scotch_6.0.3/include -I/usr/include/scotch -I../decompositionMethods/lnInclude -IlnInclude -I. -I.../OpenFOAM-6/src/OpenFOAM/lnInclude -I.../OpenFOAM-6/src/OSspecific/POSIX/lnInclude -fPIC -shared -Xlinker --add-needed -Xlinker --no-as-needed .../OpenFOAM-6/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp/ptscotchDecomp.o -L.../OpenFOAM-6/platforms/linux64GccDPInt32OptSYSTEMOPENMPI/lib \ -L.../ThirdParty-6/platforms/linux64GccDPInt32/scotch_6.0.3/lib -L.../ThirdParty-6/platforms/linux64GccDPInt32/lib/openmpi-system -lptscotch -lptscotcherrexit -lscotch -lrt -o .../OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libptscotchDecomp.so /usr/bin/ld: cannot find -lptscotch /usr/bin/ld: cannot find -lptscotcherrexit collect2: error: ld returned 1 exit status make: *** [.../OpenFOAM-6/wmake/makefiles/general:169: .../OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libptscotchDecomp.so] Error 1 How can I stop the make script from trying to use the ThirdParty directory over system packages? |
August 17, 2018, 15:16 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: There are several ways to compile Scotch and some of them are not compatible with the default build options in OpenFOAM.
I haven't checked Fedora 28, but sometime ago there was a report on how to make OpenFOAM more permissive regarding which Scotch build it is using: https://bugs.openfoam.org/view.php?id=2330 - however, the the core of the feature for allowing any Scotch build was not accepted. That said, if you can figure out which Integer/FloatingPoint combo Scotch in Fedora 28 is using, you can configure the file "OpenFOAM-6/etc/config.sh/scotch" and then use:
August 19, 2018, 01:58 |
Fedora does include a paraview-devel package, so I don't think that'll be a problem.
As for Scotch, I'm not sure how to find out what combination of bit representations it's using. The only hint I can find is in the Scotch header file. Maybe this part is relevant? Code:
/*+ Integer type. +*/ typedef int64_t SCOTCH_Idx; typedef int SCOTCH_Num; int and void (for C headers) double (for C opaque objects) INTEGER (for Fortran headers) Is this the correct way to go about finding this information? |
August 20, 2018, 15:15 |
#4 | ||
Bruno Santos
Rep Power: 128 |
Quick answers:
I haven't tried that, but in principle it's just a matter of configuring the environment variable "ParaView_DIR" to point to the base folder where ParaView has its folders... which on Fedora may be "/usr", e.g. setting: Code:
export ParaView_DIR=/usr It's later used in the folder "$FOAM_UTILITIES/postProcessing/graphics/PVReaders": Code:
echo $FOAM_UTILITIES/postProcessing/graphics/PVReaders Quote:
And possibly edit the file "OpenFOAM-*/etc/config.sh/scotch" accordingly. The RPM script used by Fedora to build the package... but am not certain where to find it. |
compile, fedora, fedora 28, openfoam |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 17:18 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
OpenFoam install script Error during paraFoam installation | SePe | OpenFOAM Installation | 10 | June 19, 2010 16:15 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
