[OpenFOAM.org] OpenFOAM 6 compilation - Pstream target directory missing |
July 11, 2018, 13:29 |
Artur
Rep Power: 20 |
Hi All,
I've just finished compiling OF6 on our supercomputer and encountered a strange issue: when compiling the Pstream/mpi and parallel/decompose shared objects the compilation script complained that it could not find the build directories for them, namely: Code:
$WM_PROJECT_DIR/platforms/linux64IccDPInt32OptSYSTEMOPENMPI/src/Pstream/mpi $WM_PROJECT_DIR/platforms/linux64IccDPInt32OptSYSTEMOPENMPI/src/parallel/decompose/ptscotchDecomp All the best, Artur |
August 17, 2018, 15:49 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Artur,
I'm a bit late to answer to your question, but I am curious as to what happened. From what I can figure out, there may have been a breaking point in communication between shells, namely:
Beyond this, if you are no longer able to try and reproduce this issue, please let us know which Linux Distribution and version you are using the supercomputer, because with luck we can reproduce this issue with a virtual machine. Best regards, Bruno
[waves2Foam] waves2Foam on an Ubuntu 18.04 with OpenFOAM 1712 | JGadelho | OpenFOAM Community Contributions | 36 | April 27, 2024 17:46 |
[swak4Foam] swak4Foam in OpenFoam 2.4.0 | avigrod | OpenFOAM Community Contributions | 8 | May 30, 2016 14:56 |
[OpenFOAM.com] Problems with OpenFOAM 1.7.1 on Ubuntu 14.10 (utopic unicorn) | alfa_8C | OpenFOAM Installation | 2 | February 3, 2015 04:16 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 07:43 |
