[OpenFOAM.com] Error ./makeParaview, VTK_QT_VERSION is '5' OF1806
Like Tree17Likes
Old   August 30, 2018, 13:46
Lourenço SM
lourencosm is on a distinguished road
OpenFOAM v1806 In Ubuntu 16.04,
to install PVReaders i had to:
1) install qt-5.9.3 (qt-everywhere-opensource-src-5.9.3.tar.xz)
cd $WM_THIRD_PARTY_DIR
./makeQt 5.9.3
2) edit the paraview confg file:
$WM_PROJECT_DIR/etc/config.sh/paraview
replace
ParaView_QT=qt-system
with
ParaView_QT=qt-5.9.3
3) Compile the PVReaders
    cd $WM_PROJECT_DIR/applications/utilities/postProcessing/graphics/PVReaders
    ./Allwclean
    ./Allwmake
NablaDyn likes this.
Last edited by lourencosm; August 30, 2018 at 13:48. Reason: append link to download qt
lourencosm is offline   Reply With Quote
Old   March 26, 2019, 09:41
Will
imamwfgf is on a distinguished road
Similar to what calim_cfd did. But after running
./makeQt 5.9.3
and
./makeVTK 8.1.1
I still can't run
./makeParaview
Not sure if it's because I skipped installing Mesa. But in the end,
./makeParaview -qt-5.9.3
worked for me
Saleh Abuhanieh likes this.
imamwfgf is offline   Reply With Quote
Old   April 25, 2019, 17:45
beatlejuice is on a distinguished road
For me the following procedure helped (OF1812, Ubuntu16.04):
Add ppa (see https://askubuntu.com/questions/1062...ubuntu-16-04):
sudo add-apt-repository ppa:beineri/opt-qt-5.11.1-xenial
sudo apt-get update
sudo apt install qt511-meta-full
create file default.conf in /etc/xdg/qtchooser with the content:
/opt/qt511/bin
/opt/qt511/lib
Version check:
qmake -v
Gives:
QMake version 3.1 Using Qt version 5.11.1 in /opt/qt511/lib
install paraview:
export Qt5_DIR=/opt/qt511/lib/cmake/Qt5
./makeParaView -cmake -qmake -qt-5.11.1
Hope this helps and it is not a stupid way =)
wyldckat likes this.
beatlejuice is offline   Reply With Quote
Old   June 3, 2019, 18:27
Saleh Abuhanieh
Saleh Abuhanieh is on a distinguished road
./makeQt 5.9.3
and
./makeVTK 8.1.1
I still can't run
./makeParaview
worked for me
That works for me too
Saleh Abuhanieh is offline   Reply With Quote
Old   June 3, 2019, 20:47
Saleh Abuhanieh
After solving that problem and compiling paraview, I received the following error when I tried to run paraFoam:
QFontDatabase: Cannot find font directory /opt/OpenFOAM/ThirdParty-v1812/platforms/linux64Gcc/qt-5.9.3/lib/fonts.
Note that Qt no longer ships fonts. Deploy some (from http://dejavu-fonts.org for example) or switch to fontconfig.
I found the solution, and posting here:
- cd /opt/OpenFOAM/ThirdParty-v1812/platforms/linux64Gcc/qt-5.9.3/lib/
- ln -s /usr/share/fonts/truetype/dejavu/ fonts
That's all
Regards,
Old   June 21, 2019, 11:03
Jesper R. K. Qwist
Jesper_Roland is on a distinguished road
Originally Posted by TU_Hiwi View Post
okay so i now could install paraview using qt 5.9.5, which should also be LTS. (by the way, is there a difference between "qt-everywhere-src-VER" and "qt-everywhere-opensource-src-VER"?)
installing paraview worked just fine, but if i execute paraFoam the "missing PVFoamReader"-error pops up. Paraview opens up anyway but the fonts (and so any text) is missing. Not suitable for working, i would like to solve that
executing the advised commands (cd $WM_PROJECT_DIR/applications/utilities/postProcessing/graphics/PVReaders
./Allwclean
./Allwmake) works until some error during ./Allwmake state below.
CMake Error at /home/hgl/OpenFOAM/ThirdParty-v1806/platforms/linux64Gcc/ParaView-5.5.2/lib/cmake/paraview-5.5/ParaViewQt.cmake:71 (find_package):
  By not providing "FindQt5.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "Qt5", but
  CMake did not find one.
  Could not find a package configuration file provided by "Qt5" (requested
  version 5.6) with any of the following names:
    Qt5Config.cmake
    qt5-config.cmake
Any Ideas what went wrong and how to solve?
You can also search for the missing files by:
So for example in my case it cannot find Qt5CoreConfig.cmake.
Follow these steps:
3.1) sudo apt update (Only the first time you search for files.)
3.2) apt-file search Qt5CoreConfig.cmake
3.3) It should now return a message similar to the following:
qtbase5-dev: /usr/lib/x86_64-linux-gnu/cmake/Qt5Core/Qt5CoreConfig.cmake
3.4) So we need to install qtbase5-dev. This is done with the command:
sudo apt install qtbase5-dev
3.5) Now you can run your the paraview compilation again:
./makeParaview
Now it just repeating until you have all the required files and installations.
wbywbywby6 likes this.
Jesper_Roland is offline   Reply With Quote
Old   July 22, 2019, 23:07
Glenn Carlson, PE, PhD (ret)
gcengineer is on a distinguished road
Thanks for this, Jesper.
This is essentially the same as my solution for building ParaView 5.6.0 with Qt5 for OpenFOAM-7 and OpenFoam-v1906 running under Ubuntu 18.04:
Qt5, OpenFOAM-7 and -v1906, and Ubuntu 18.04
Gerhard likes this.
gcengineer is offline   Reply With Quote
Old   October 18, 2019, 11:06
Default Finally solved this problem!
  #28
Rasmus Iwersen
Rasmusiwersen is on a distinguished road
Follow these steps:
./makeParaview
Once again Jesper, thank you for the suggestion. I've had this problem at every build of OF19.06, but this actualyl worked!
Hope you are doing well
Happy foaming!
Rasmusiwersen is offline   Reply With Quote
Old   April 20, 2020, 14:45
Gerhard
Gerhard is on a distinguished road
Hi everybody,
I had the same error as in the first post for OF v1912 and OF v1906.
I found this link, followed it exactly, and it solved my problem! Here it is:
https://zhuanlan.zhihu.com/p/82423956
All the best!
Gerhard is offline   Reply With Quote
Old   May 30, 2020, 06:01
NablaDyn's Avatar
NablaDyn is on a distinguished road
FYI:
I received an error message during compilation ("make" on Ubuntu 20.04 LTS, OpenFOAM-v1912) of qt-5.9.3 from this source
regarding something like:
socketcanbackend : error: ‘SIOCGSTAMP’ was not declared in this scope; did you mean ‘SIOCSARP’?
As suggested on
https://www.mail-archive.com/blfs-de.../msg08916.html
this was successfully fixed by adding
#include <linux/sockios.h>
to the file
qt-everywhere-src-5.13.0/qtserialbus/src/plugins/canbus/socketcan/socketcanbackend.cpp
A fix for a succeeding error
Project ERROR: Building QtQml requires Python.
is already given here:
failing to build Qt, Project ERROR: Building QtQml requires Python. - ubuntu
anufagbemi likes this.
NablaDyn is offline   Reply With Quote
Old   July 25, 2023, 20:47
Default Hmm. Looks familiar.
  #31
Wow. zhuanlan.zhihu.com stole my solution word-for-word that I posted here on CFD-online in 2019.
[OpenFOAM.com] Install OF1806 with system thirdparty packages Bloerb OpenFOAM Installation 1 October 5, 2018 06:49
[OpenFOAM.com] problem: compiling of1806 on ubuntu 14.04 gian93 OpenFOAM Installation 2 August 8, 2018 10:03
