[OpenFOAM.com] Developing Applications/Libraries Using OpenFOAM on Windows (docker version) |
June 28, 2018, 00:18 |
Rep Power: 8 |
I just downloaded OpenFoam v1712 using the docker-based installation for Windows 10. I can run tutorials just fine and modify the program geometry and other details, but what I would really like to do is to be able to modify the source code to tailor it to my needs. Is this possible using the docker version or will I have to natively run it on Linux?
July 10, 2018, 03:03 |
matej forman
Rep Power: 17 |
Sure possible. Just do it! Copy the source you want to modify, edit the source code in your favorite windows editor (mine is Atom) and go back to the docker terminal and type: wmake If everything set properly you will have your new app. Docker container contains CentOS system with bcc compiler with witch OpenFOAM was compiled there. |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[OpenFOAM.org] Who has an old version of OpenFOAM for windows | lilinmin | OpenFOAM Installation | 0 | December 12, 2016 23:55 |
Difference between OpenFOAM on Centos 7 and On Windows 10 (cygwin) | JensGoldberg | OpenFOAM Programming & Development | 0 | November 10, 2016 03:30 |
Could not find surfaceFeatureExtract in Windows version OpenFoam 2.2 | liyy3528 | OpenFOAM | 0 | August 21, 2016 00:05 |
OpenFOAM (Linux) in a MS-HPC-Cloud | fossy | OpenFOAM | 6 | September 23, 2010 11:48 |
