[Other] How to install numpy on CentOS/RHEL 6.x?
Old   May 30, 2018, 09:15
Default How to install numpy on CentOS/RHEL 6.x?
Vania
VLima is on a distinguished road
Dear all,
I have a problem using Python within OpenFOAM.
It is installed within OpenFOAM (verified via opening terminal and typing "python" - version 2.6.6 btw) but does not recognize the packages numpy, etc :
bash-4.1$ python
Python 2.6.6 (r266:84292, Jan 22 2014, 09:42:36)
[GCC 4.4.7 20120313 (Red Hat 4.4.7-4)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import numpy
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
ImportError: No module named numpy
So the problem arises when I run some case that has to run a Python script :
bash-4.1$ bash runCasePiston
blockMesh meshing...
Preparing 0 folder...
Setting the fields...
Creating piston wavemaker movement...
File "pistonWaveGen.py", line 3, in <module>
import numpy as np
I manage to run the python script outside OpenFOAM but this is not a practical nor wishful solution.
I do not want to mess much with my Python installations, as they are bounded to work with other codes.
So my question is how to solve this issue, concerning the Python packages recognition, within OpenFOAM?
Hope I was clear.
Looking forward for your help!
Thank you in advance.
VLima is offline   Reply With Quote
Old   May 31, 2018, 09:30
Retired Super Moderator
Bruno Santos
Quick answer: You will still need to install numpy, but you can choose to either install it at the system-level or install it as a normal user: https://superuser.com/questions/4656...os-6-2-64-bit/
Due to numpy being a fairly standard Python package, I believe you can install it without interfering with other Python packages and current installation.
[OpenFOAM.org] Install OpenFOAM without admin right OpenFoamlove OpenFOAM Installation 1 December 31, 2017 12:45
error make SU2 4.0.1 Heathckliff SU2 Installation 2 November 9, 2015 06:48
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 kobayashi OpenFOAM Community Contributions 2 January 5, 2014 18:33
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 12:18
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 15:43
