[foam-extend.org] foam-extend-3.1 multiple versions paraview issue |
May 25, 2018, 21:48 |
Dear OpenFOAM users,
I will try to be as detailed as possible. I have OpenFOAM 5.x installed and running fine. I tried installing foam-extend-3.1 by downloading and running binary: $ sudo dpkg -i foam-extend-3.1_amd64.deb Before running dpkg, I followed Ubuntu prep work: sudo apt-get install git-core build-essential binutils-dev cmake flex bison zlib1g-dev qt4-dev-tools libqt4-dev libncurses5-dev libiberty-dev libxt-dev rpm mercurial graphviz ======= FYI +++===== Linux core on Win10: lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 14.04.5 LTS Release: 14.04 Codename: trusty ================== After trying to install binary with dpkg, the shell returns error: Selecting previously unselected package foam-extend-3.1. (Reading database ... 117165 files and directories currently installed.) Preparing to unpack foam-extend-3.1_amd64.deb ... Unpacking foam-extend-3.1 (3.1-1) ... dpkg: dependency problems prevent configuration of foam-extend-3.1: foam-extend-3.1 depends on paraview; however: Package paraview is not installed. foam-extend-3.1 depends on paraview-python; however: Package paraview-python is not installed. foam-extend-3.1 depends on hwloc; however: Package hwloc is not installed. dpkg: error processing package foam-extend-3.1 (--install): dependency problems - leaving unconfigured Errors were encountered while processing: foam-extend-3.1 =================================== Even though there was error, foam-extend-3.1 has been installed into /opt/foam/foam-extend-3.1 OpenFOAM 5x is installed into /opt So, the current content of /opt directory is username:/opt$ ls foam openfoam5 paraviewopenfoam54 I tested fe31 works fine and calculates the icoFoam case. However, paraview does not work. Then, I reloaded the environment with of5x and ran parafoam. It worked (ParaView 5.4.0 64-bit Legacy Rendering Backend). =================================== My questions are: 1) Should I worry about installing paraview, python-paraview, hwloc ? I assume OpenFOAM 5.x. has this packages already. 2) Do I need to / How to fix dependencies error described above (namely, paraview, python-paraview, hwloc) ? 3) (Optional) Can someone briefly clarify why such issue arise in the .deb ? 4) Is there a binary for foam-extend-4.0 on Ubuntu 14.04 ? or I need to build it from source ? 5) What is the elegant way to have parafoam work when fe31 environment is loaded? Could someone please point me in the right direction ? 6) Do you think fe31 has been installed fully ? Thank you in advance, CFDpal |
May 31, 2018, 09:51 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answers:
fe31, foam-extend-3.1, multiple versions, parafoam, paraview |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
[foam-extend.org] Foam extend 3.1 on SLE12? | Berin Šeta | OpenFOAM Installation | 1 | November 20, 2015 06:31 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 22:41 |
