[foam-extend.org] foamExtend 4.0 nextRelease Installation failure |
May 17, 2018, 12:14 |
Rep Power: 9 |
Hi everybody
I'm trying to get my hands on the nextRelease of foamExtend 4.0 to test the oversetmesh functionality. But the compillation failed. Here's what I did: I set up a brand new VM Ubuntu 16.04, cloned foamExtend 4.0 and compiled it accordingly to the description in the openfoam-wiki with Allwmake.firstInstall. I tried some basic tutorials and so far it worked. Then I checked out the nextRelease branch and compiled it with Allwmake. Now I expected the overset tutorials to work. But the solvers don't seem to work. Attached xou find my log file "log.make" I recorded with ./Allwmake > log.make Also there's my log from foamInstallationTest attached. Any advice would be highly appreciated. chris |
May 31, 2018, 09:55 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: You need to either use a different "WM_COMPILER" option, or you need to clean up the previous build.
The problem here is that a ton of changes have happened and having the previous build still at the "linux64GccDPOpt" folders, is resulting in confusion on the wmake script-stack. To do a clean up, first run: Code:
wclean all
July 15, 2018, 08:38 |
Rep Power: 9 |
thanks Bruno for the hint. I tried Icc instead of Gcc and it worked.
chris |
foam extend 4.0, installation |
[OpenFOAM] postprocessing 3dTube tutorial in fsiFoam - foamextend 4.0 | sangeet | ParaView | 1 | July 13, 2018 07:29 |
[Other] installation of OpenFOAM V.5, OpenFOAM+ v1706, and foam-extend 4.0 all together | Ash Kot | OpenFOAM Installation | 2 | May 31, 2018 20:03 |
[OpenFOAM.org] OpenFOAM 4.0 installation in CAELinux 2013 | leee | OpenFOAM Installation | 1 | February 24, 2018 19:18 |
[swak4Foam] swak4Foam installation on OpenFOAM 4.0 | blttkgl | OpenFOAM Community Contributions | 1 | March 14, 2017 12:06 |
SU2 installation succesful but failure when running | rfadlika | SU2 | 3 | November 2, 2015 19:42 |
