[OpenFOAM.org] build paraFoam on Debian stretch |
May 14, 2018, 08:52 |
Gianluca
Rep Power: 14 |
Hi all,
I have been playng to install OpenFOAM and ParaView on a Debian Stretch with amd64 arch: I tried with OpenFOAM 5.0 and ParaView-5.4. source distribution. At the end both of them where successfully built. Tryiing finally to build paraFoam (PVReaders tree) the compilation failed mostly, I believe, because of crappy wmake environment variables for include files. Afterwards I realized that now Debian Stretch offers packaged version of OpenFOAM (4.0) and ParaView (5.1.2) so I successfully installed both and they both work as expected. I can build a mesh with SHM and visualize it with foamToVTK and paraview. Unfortunately openfoam package is missing the so useful paraFoam utility which many times has helped me to solve errors with blockMeshDict with the powerful option '-block'. How can I overcome this issue? Thank you for your help. Regards Gianluca |
May 28, 2018, 09:26 |
paraFoam missing from openfoam debian package
#2 | |
Gianluca
Rep Power: 14 |
I'm wondering no debianized is using OpenFOAM? I still did not find any workaround. please help if you can Gianluca |
May 31, 2018, 09:06 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Ubuntu is based on Debian, therefore the installation instructions for Ubuntu should work on Debian, as long as the Debian-Ubuntu versions are related.
As for the specific build problem you are having, it would make it a lot easier to diagnose the problem if you had provided the build output. You can do this by running: Code:
cd $FOAM_UTILITIES/postProcessing/graphics/PVReaders ./Allwclean ./Allwmake > log.make 2>&1 pwd gzip < log.make > log.make.gz Furthermore, knowing which installation steps you've followed would also help diagnose what might be missing. As for the "openfoam" Deb package that Debian provides, that was done without the suggestions given by the OpenFOAM Foundation, which might explain the problem you're having with that package.
build, debian, parafoam, stretch |
SU2 Parallel Build Install Issue | jclegg | SU2 | 4 | October 20, 2020 04:28 |
[OpenFOAM.com] paraFoam cannot open due to Qt issues - [Solved/Information] | u2berggeist | OpenFOAM Installation | 2 | July 2, 2018 17:03 |
Building from Source on Windows using Cygwin64 | ericthefatguy | SU2 | 2 | May 12, 2015 18:23 |
paraFoam Build Issues | vbchris | OpenFOAM Installation | 1 | September 13, 2014 15:23 |
paraFoam "Fatal Error" on Debian Wheezy/Sid | ned800 | OpenFOAM Installation | 3 | October 24, 2012 11:26 |
